Old 12-21-2017, 10:10 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Originally Posted by sawdustdad View Post
Not planning to add a lift. Dump bed is the plan.
I understand that, but you CAN have both...
I just think it would be really cool. You'd never need front weights
1- 1200 in pieces
1- 1864 in pieces
Old 12-21-2017, 10:32 PM
Dirty Steve's Avatar
Originally Posted by DoubleO7 View Post
Must be a 6x4 Hydro 244
244 is a result of 147+109-14hp-10hp+12hp = 244
I like the 244.
How about 244+2 Hydro
(244+ 2 xtra wheels)
Or "Ten 2+2"
Ten (plus) 2hp + 2 wheels
Old 12-21-2017, 10:51 PM
sawdustdad's Avatar
Terra-Cub 2612
On another note, I think it needs lug tires up front too. Just goes with the whole theme.
____
Last time I put ags on the front, someone here made fun of me. It hurt my feelings something fierce. I did it anyway, and, just to be ornery, I put ags on the front of a couple other cubs.
But I like the way you're thinking, Jonathan.
Old 12-21-2017, 10:54 PM
Yeah..... normally I don't like ag's on the front, but you don't see tandem axle tractors either, so I'll make an exception.
Who was that guy poking fun anyway....
Old 12-21-2017, 10:57 PM
sawdustdad's Avatar
Can you see me showing up at a plow day with this?
I've already removed the lift lever (it was jammed up inside) and other lift components. Only thing left is the rockshaft itself. Not that it couldn't be fixed and re-installed. Would need a loooonnng link arm from the rockshaft to the rear end. Or rig up a Sam Mac winch powered lift.
Old 12-22-2017, 12:13 PM
Jumper Jumper is offline
Looks like a lot of room between the transmissions to mount a cylinder. JD used a cylinder with a elongated end on the piston to allow the system to float. I think you could make it work here. Nice looking project, by the way.
Sorry about the picture, only one I had.
Old 12-22-2017, 01:44 PM
Rescue11's Avatar
YES!!
I mean a category 0 3 point. You could do as jumper suggested or the way Keith and I did his cat 0. Just figured it would add to the uniqueness of your build
1- 1200 in pieces
1- 1864 in pieces
Old 12-22-2017, 05:51 PM
twoton twoton is offline
Very cool, dump truck with a cat 0.
LTT 12000 Long tail tandem 12 HP
Old 12-22-2017, 10:04 PM
sawdustdad's Avatar
Had to run to Richmond today, so didn't get much time in the shop. Our son (29 years old) came today to spend Christmas with us.
After dinner, I got an hour or so, so I mounted the starter and belt, and spent some time cleaning up some old wiring for lights (replaced switch and ran new wires fore and aft for future lights) and made a new positive battery cable to run from the starter relay all the way to the rear of the tractor where I think the battery will reside when I'm all done.
Started on the gas tank. The existing tank is pretty beat up and has some debris inside it. So I decided to pull a spare that I will use.
My original plan was to leave this tractor as is, cosmetically, until it is running, then come back and pretty it up. But as I work on it, I think about the extra effort to come back and disassemble, paint, etc, so I'm taking some time to deal with areas that might not be accessible after it's in running shape.
No pics this time. Use your imagination!
Old 12-23-2017, 05:27 PM
sawdustdad's Avatar
Only minor progress today. Not so exciting waiting for paint to dry...
cleaned, primed and painted the fuel tank. Installed the tank supports. Hooked up a jump pack and "energized" the wiring harness. Starter relay is stuck or failed open. Jumped it and the engine turned over. No fuel system, so no start.
No IH dealer within 60 miles of where we live now, so I got some paint at a Tractor Supply store. Magic (or majic?) brand. Close color match but slow to dry and I don't care for the circular spay pattern.
One pic of the new positive battery cable (even though it's black--will add some red tape to it shortly) and the coiled up yellow cable for tail lights. Need to drill and tap a hole for a battery ground, (or make another cable to run forward to the starter ground, which, actually is better). I have the cable and terminals...)
OK, a couple pics...
