Old 12-22-2017, 08:36 PM
cadetmike's Avatar
cadetmike cadetmike is offline
Default Hey from (chilly) New York
Hello all!
Looks like I have found a wholesome forum with some great info! I am an experienced (auto) mechanic and I do a good bit of fabricating and tinkering with small engine stuff on the side.
I have owned a couple Cub's newer and older. My current project is a 122, I recently purchased a Brinly plow and fabricated a sleeve hitch for it along with a electric lift feature. I am currently working on doing a v-twin swap, and considering putting 26x12 ag tires on the rear. My problem is I cannot leave anything I own stock, soooo I would also like to paint the rig in a traditional red IH theme. The main use for the tractor will be plowing (snow and ground) as well as other utility work, so I am not much concerned about the affect of the modifications on fitting a mower deck. I am open to ideas and such for my project!
Old 12-22-2017, 10:17 PM
athomas's Avatar
athomas athomas is offline
Welcome ! sounds like a good project, i'm sure you'll get some ideas here !
Old 12-23-2017, 12:35 AM
johncub7172's Avatar
cadetmike Welcome to OCC! The best IH Cub Cadet forum on the net! Sounds like you are having fun with a custom build! Having two separate lifts on a gt is awesome. Lots of good help from the group. Post pictures, and ideas will be had!
Merry Christmas!
Old 12-23-2017, 08:28 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Hello Mike and welcome.
I'm sure we'd enjoy pix of your project!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-23-2017, 08:38 AM
Bamafan Bamafan is offline
Inactive Member
Lots of great info. here. We like pics.
[B]Larry[/B]
Old 12-23-2017, 09:20 AM
cadetmike's Avatar
I appreciate all the feedback and interest! I will probably start a project thread in the "IH Tractors" section (with pictures). My biggest hold up at the moment is acquiring an engine, I have posted in "wanted" so we will see what turns up. This is a budget build, so I don't have $1500 to shell out on a new engine.
Old 12-23-2017, 09:31 AM
I have a suggestion:
Put a built up K series Kohler in your 122. No better engine suited for that tractor. If you are any good at being a mechanic, rebuilding that engine will be a breeze. You can do a cam upgrade with some other mods and I think you will find that single cylinder to be pretty impressive. No need to hack up the frame and go jamming an oversized v-twin in that lacks torque and doesn't fit.
26x12-12 tires on the rear are too big to plow with. Even on a 12" plow a 12" tire doesn't fit well in the dead furrow. All the guys who understand plowing know this as fact. The best plow tire is a 23x8.50-12. Plus, going to a larger tire screws pretty bad with your drive ratio. You'll have to do some gear swapping to get things back right again.
I'm sure you will ignore what I have to say, and lots of people who have never swapped a motor in anything or pulled a moldboard plow will tell you I'm wrong. Be careful who's advice you take.....
Welcome to the forum!
Old 12-23-2017, 11:18 AM
cadetmike's Avatar
J-mech, thanks for the input. I appreciate the suggestions and insight, you make very good points. do you know if a 16hp k series will bolt into that frame?
I just want more hp and torque than the 12 is delivering.
Old 12-23-2017, 11:28 AM
IHinIN IHinIN is offline
A K301 12 hp is the largest engine that will fit without frame modification. The 14 & 16 hp have a larger flywheel and won’t fit between the frame rails.
Jmech is right about the 26x12x12 tires being too wide for plowing.
A 12 hp has plenty of power to pull a 10” plow
Old 12-23-2017, 11:35 AM
That to me sounds like excellent advice given! I'd stick with a bored out, rebuilt, and hopped up Iron Line Kohler K301 for your 122. Or, you might find a great running K301! They have power, and longevity! Unlike the expensive task of repowering a 82 Series.
Also, I have read many times that the rear tires standard to a SGT, also have the gear ratios proportioned correctly. To what degree I can't say. If this is going to be a budget build, then consider the suggestions.
Perhaps you are going to surprise us with a twin cylinder repower?
