Old 10-09-2010, 06:10 PM
juniors1282's Avatar
Got the rears done today. Those old sears wheel weights don't look to bad IH white!
1966 IH cub cadet 102x2
Old 10-09-2010, 08:48 PM
Nice looking cubs! Wish mine looked that good!
I got some more seat time today but with both kids sick my wife didn't snap any pics. I got to break in the tiller and I like plowing better! It did a good job but after doing a total of 6 beds I'm wore out from using it. I had to go over the beds a couple times to break up some of the larger clumps. Where I expanded the one bed was time consuming trying to get it worked in right. I'm going to get the home owner rake it out. It was almost like work. I'm sure a hydro unit would've been easier to use and on me.
Old 10-09-2010, 09:03 PM
kwduffy
102 is looking good with the new tires
juniors1282
Wheel weights look great IH White
Methos
Glad you got the tiller broke in :biggrin2.gif:
Hope the kids get to feelin better.
Old 10-09-2010, 09:11 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
got the grass cut and ran the lawn sweeper because leaves are starting to fall, got this sweeper in spring because it was large "25 cu. ft. hamper capacity (29 bushel capacity)"
but i want to tell you i took 10 loads out of the yard and leaves are still mostly green here.will just push the sweeping in to a pile on property line later
after that pulled cub into garage and put the chains on the tires for snow season, would rather do it now when time is on my side and the weather. also put stud kit on axels for easier tire swaping. standerd tire bolts are ok if you only change when they wear out but they can be a pain somtimes, like it much better with wheel studs and nuts, the way it should have come out of the factory in my opinion.
Old 10-09-2010, 10:33 PM
Nice cubs, guys!
Duke: Hope the kids start to feel better real soon.
Old 10-10-2010, 04:08 AM
Thanks guys!
Old 10-10-2010, 08:58 AM
toyman's Avatar
toyman toyman is offline
Junior & Kduffy - tractors are looking good!
After a cool rainy week in PA, my garden has stopped producing (almost), so I pulled most of the plants and tilled up the garden. Left a few pepper plants that had a few dozen coming in and a zucchini with a few left. Had a slight issue with a relief valve leaking, but a quick clean and replace and all was well again. I'll still need a load of mushroom manure and another tilling before I put it up for the winter. I will be getting the 450 blower mounted on the 1862 in the next few weeks along with an oil & hy-tran change. Here's a few pics from yesterday.
Original Member #54
Old 10-10-2010, 09:19 AM
toyman
Great pictures of the 982 and tiller
Old 10-10-2010, 10:25 AM
Awesome pics, toyman! The 982 and tiller did a great job.
Old 10-10-2010, 04:31 PM
nickvanorman
Guest
Posts: n/a
took my 122 out for a spin today. still runs great. i see no problems yet and hope i wont since i replaced just about everything in it electric wise to get it to charge and start with the key. goes anywhere with the Titan true powers on it and the wheel weights. can't wait for winter to see what it will do. sometime soon, i have to get the motor rebuilt. shes pretty tired and in need of it bad. but thats for a later date.
