Old 12-30-2017, 08:25 PM
gscott gscott is offline
Default Much thanks
Got it figured guys.
darkminion_17 drew my attention to using aftermarket parts.
Pulled the engine off and clutch assembly out.
Mic'ed the aftermarket plates with my original plates....after market plates MUCH thicker, took up the free play area.
I was trying to beef things up a bit...am installing a K341 on the 73. Its a workhorse around here.
Had already resurfaced the original plates, so just used those. Everything A-OK now.
Thanks again guys.
Old 12-31-2017, 08:06 AM
mickb72 mickb72 is offline
Hello, if those are Zack Kerbers, i know his pulling plates are thicker and use different hole locations for the driveshaft. I don't know if he has stock plates. Mike
Old 12-31-2017, 08:45 AM
Default You are right...
mickb72 you are correct those are Zack Kerbers.
I didn't know they were that much thicker.
I see he has drive shafts as well, however trying to find a machine shop around here to drill the hole for input shaft is like pulling teeth.
Thanks for all the info guys.
Old 12-31-2017, 08:08 PM
I make driveshafts plus other parts. http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Tell me the locations you want the holes and I'll make it to your specs. $30 plus shipping.
Jeff
Old 12-31-2017, 08:22 PM
twoton twoton is offline
If your plates are too FAT and you aint got no machine chop available I bet Jeff would skinny em up for ya to if you asked??
Old 01-01-2018, 12:21 PM
I can thin your plates too. Your choice on either option
Old 01-01-2018, 02:36 PM
I think that clutch was a bit overkill for the application..... but whatever.
I wouldn't turn the disk down, as you spent the money on a heavier set up....why kill it? I would suggest getting the proper shaft made.
Old 01-01-2018, 03:49 PM
Merk Merk is offline
New driveshaft?
Who drilled the holes.
Are you using a Cub Cadet throw out bearing or an aftermarket throw out bearing?
It sounds like the holes in the drive shaft are in the right location. I've used the thicker clutch plates and didn't have any problems. You should have enough adjustment using thicker plates.
by J-Mech
I'm using stock clutch plates with a blue spring and a Kevlar clutch disc on my 100. I have no slippage issues with this set up. Engine is making around 14 horse power and pulls a 10 inch plow at plow days.
Project Uncle Dick
Cub Cadet 70
Old 01-01-2018, 04:25 PM
When I assembled the clutch pressure plates and drove the spiral pins in, it was already tight enough that the disk would not move.....
New driveshaft?
Who drilled the holes........
Looks like one of Zach's 6 pin drivers...
Me thinks that you may have ordered the wrong driveshaft there gscott.
Zach has two versions, narrow hole and wide hole...
Old 01-01-2018, 04:37 PM
I never used on of Zach's 6 pin drivers. Are they the same measurements in terms of thickness????
by Merk
Today 02:36 PM
Yes I am aware he has a Zach 6 pin driver.
I just stated what I use.......no need for overkill.
Project Uncle Dick
Cub Cadet 70
