Old 01-06-2018, 05:52 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Default Winter storage
As a reminder, if you haven't done it lately, go put a charger on your batteries. I just checked the brand new battery in my Chevelle and it read ZERO volts. Oh well, it's under warranty. Maybe it will recover.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 01-06-2018, 06:06 PM
Works best if you disconnect battery cable while in storage.
They will take maybe 5-8 total discharges like that before they fail----- usually
I dislike battery maintainers but not going into a discussion
LUCK!!
Old 01-06-2018, 07:12 PM
twoton twoton is offline
..... but not going into a discussion....
Are you sure...... I'd like to hear your thinking on this...
Old 01-06-2018, 07:19 PM
Billy-O's Avatar
Billy-O Billy-O is online now
I believe trickle chargers can overcharge the battery if you leave it on too long.......even if you are doing trickles. I have trickle charger that will stop charging once the charger senses the battery has full charge so I think that's OK.
Plow blade
#2 Cart
QA36 snowthower
Old 01-06-2018, 08:30 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
A "float charger" is the way to go on a stored battery.
an example: https://www.ruralking.com/auto-batte...SABEgI3MfD_BwE
Old 01-06-2018, 08:46 PM
OK,
The problem with maintainers I've seen is the battery will come up to voltage and shut off.
Then when it drops a bit, it will kick in.
After a long period of this,. the battery takes on a surface charge.
Then when it is asked to start the equipment, it is dead.
A trickle charger will over charge a battery, seen it time and time again.
Same thing in a RV with a "trickle" power supply, come spring you find a dry battery that is junk.
A maintainer will work ok if only used month to month usage.
like my ol vette, I don't use it weekly in summer, maybe once a mo. or less, in that situation a maintainer works ok.
(I don't own/use a maintainer)
Just my findings over many years.
Old 01-06-2018, 09:23 PM
SS5150's Avatar
SS5150 SS5150 is offline
I've had similar issues with maintainers on my sleds and Monte Carlo. Keep them on and I go to use them and the batteries are dead. Stopped using them.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 01-06-2018, 09:34 PM
Hard to know what the best thing to do is, I guess just keep using your stuff.
Back when I had the time I would always just pull all the batteries in the unused equipment and store them in the warm boiler room on a pine board on the floor. Charge them in the spring when it was time to get going.
When I was a kid and bought my first motorcycle, the guys said, “ come winter, put the battery in the cellar with a trickle charger hooked up to the cellar light. That way, every time your mom sends you down to get a can of beans out of the root cellar, the battery will get some charge”.
I got a friend that made up a pulse charger recently. Swears he’s gonna rejuvenate all his 15 year old batteries.
Lately I been using Battery Tender Jr’s.
Sorry, just some random thoughts..
Old 01-06-2018, 10:41 PM
V30crewcab V30crewcab is offline
Yeah I forgot to check two of mine that I wouldn't usually worry about. went to start one, and it was stone dead. it has been down to 8 degrees for a few days. so far haven't gotten either to come back at all. sucks. If I had to replace all my batteries here I'd be north of 1500 in them all at the minimum. might need to get rid of a few things!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 01-07-2018, 08:57 AM
cubby102's Avatar
cubby102 cubby102 is offline
Honestly i had great luck out of my old battery tender plus. It finally died after 5 years of abuse. I used it to charge my deep cycles mainly and i think thats what killed it (would take 4+ days to charge two batterys) ive had those for 4 years now and still going strong. I also use it to keep the battery topped up in the cub between usage in the winter. I pull the battery out of my s10 and bring it inside on the heat and will throw the maintainer on it for a few days every other week. And rotate with a couple other batterys i have. So far ive lucked out with it. And brought one battery "back" with it for 50 bucks i really cant complain. I need to buy another soon
