Old 01-06-2018, 12:02 PM
I'm not sure a pot metal emblem will stand up to have anything pressed into it. I'd be worried about cracking it and then it would be junk.
Old 01-06-2018, 12:04 PM
drcjv's Avatar
drcjv drcjv is offline
I was thinking that also Tim.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 01-07-2018, 12:05 AM
http://www.onlycubcadets.net/forum/s...571#post366571
Old 01-07-2018, 12:53 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I'd make a new plate slightly smaller than the emblem out of thin metal.. drill thru the thin plate.. tack weld in two studs.. then glue, epoxy or use two sided tape to attach original emblem to the new plate with studs..
Or what Todd (Zippy) did would be quicker and just as effective..
Or use the bottom stud along with some 3M double sticky emblem tape and just attach straight to the grill screen.. That stuff is super strong.
Just for info my yellow 982 Super has the CCC emblem.. the tractor is very original and has never been monkeyed with.. It has the same patina and aging as the rest of the tractor.. it's obviously been with the tractor a long time.. I've always wondered why they discontinued the use of the emblem so quickly after the formation of CCC.. I've never seen them past about 1983 on either the garden tractors or supers..
Jay
Proud owner of the following:
Old 01-07-2018, 12:09 PM
Baccarat Baccarat is offline
Yea Charles, Tim is correct about the pot metal possibly being a problem. I hadn't thought of that scenario. It probably would crack when a PEM was pressed into it. Even with proper tooling it would still be problematic. I avoid pot metal like a plague.
My apologies.
Old 01-07-2018, 01:38 PM
jbrewer's Avatar
jbrewer jbrewer is offline
3M double sided automotive trim tape.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-07-2018, 02:19 PM
drcjv's Avatar
Any idea where to get part #for emblem
2072 50" deck
Old 01-07-2018, 04:36 PM
jaynjeep's Avatar
Charles,
I found it here.. with a weird part number 222-4798
https://www.ihccw.com/grilles.html?product_id=2722
Jay
Old 01-07-2018, 05:15 PM
drcjv's Avatar
Jay I saw that too but can't find another reference with that #.
2072 50" deck
