Old 01-05-2018, 11:26 PM
Kubota L3400 is more like #2500. Unless you had loaded tires or wheel weights on it.
Here's my questions:
*Was/is it 4x4?
*Do you still have it?
*Have you bought and installed tire chains on the front of the 782?
I've got the L3400 Jon, with loader and loaded rears, and a scale right next door, but never thought of weighing it. Will have to for shits and grins this spring to see...
Moved snow with that tractor, many of times. NEVER needed front chains. If/when the front tires lose traction, raise the bucket a little. Right?
PO, why not use the Bota for your snow removal?
Old 01-05-2018, 11:33 PM
Todd, I was going by the listed weight of the tractor. I'm familiar with the L3400.... I thought 3K sounded high, do I looked it up. With a loader, I'm sure it is 3K.
Yeah.... I too was wondering if the OP still had that tractor, why it wasn't getting used for snow removal. Believe me, Id use something bigger if I had it. But the Cubs are pretty handy for pushing snow in small areas.
Old 01-07-2018, 09:30 PM
I haven't tried chains up front but I do know that narrow tires work better than wide tires up front.
As soon as we get enough snow to use my 125 with the QA-42. I will let you know if tri ribs up front work better than factory "skinnies".
Did a little after storm clean up today and tri ribs do work better that regular skinnies.
Old 01-07-2018, 10:57 PM
Old 01-08-2018, 12:15 PM
Tony h's Avatar
Tony h Tony h is offline
*Was/is it 4x4?
Yes ,4x4 Loaded tires.
Yes I still have it.
No it wont work for the plow area I am using the Cub on.
L3450 to be exact.
If I can't fix it , it must not be broken
Old 01-08-2018, 02:07 PM
What do you mean it won't work? It's a driveway right? Tractor is no wider or larger than a car.... why wouldn't it work?
