Old 01-16-2018, 09:12 PM
V30crewcab V30crewcab is offline
well I cranked my 1862 and 1641 today just to make sure one of them would run to plow if we get enough. both been sitting for 2-3 months, so it took a bit to get the fuel up to them, other than that only problem is the 1862 bendix is pretty unhappy. I need to pull it off and clean it up but haven't had time.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 01-16-2018, 09:26 PM
yettrbomb yettrbomb is offline
My 1812 starts hard when it’s cold. I’ve started taking the battery out of it and keeping it in the basement. The big cold snap we had a while back, froze my battery. Not gonna but one til spring (I hope). After I get one, I may keep a tender on it once in a while. But doubtful
Old 01-16-2018, 09:27 PM
The only time I've ever had a Cub that was hard to start it was because it still had 30w oil in it. My 1050 sat outside all last winter at my mother in laws and it always fired right up when i'd go over to plow.
Old 01-16-2018, 10:28 PM
bocephus1991's Avatar
Mine don’t get any colder than bout 40-50 in the basement garage! Lol have a battery maintainer on them. Non-alcohol gas. Throttle at idle and choke them, usually fire first time
Brian
Old 01-17-2018, 10:52 AM
johns cubs's Avatar
johns cubs johns cubs is offline
Originally Posted by Marko141 View Post
Scared of the snow that's funny! I don't think my 127 minds the snow, it sleeps outside!
My 124 also sleeps out side, with the seat up. I have a small car battery in it and withing 2 revs its running. Knock the snow off and let it warm up while I clean the wifes truck off and we are ready.
John
Old 01-17-2018, 01:30 PM
Nightow1 Nightow1 is offline
Change my oil from summer to winter every year, keep them turned well and I take care of them. All I have is a battery tender which is why i have had the same battery for like 6 years. last snow it was -22 deg. 782 started up on second turn.. Never an issue, I do however let it warm up in winter for around half hr... mostly because I have a lot of hydraulics on her ITS SLOW lol
Old 01-17-2018, 04:31 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
My 149 with snowblower sits in a heated garage, 50 to 60 degrees in winter depending on outside temperature. Should I change to 10w30 oil or leave the 30 wt. in the tractor? Have a great day
Thanks,
Bob
Old 01-17-2018, 06:23 PM
athomas's Avatar
athomas athomas is offline
I know what the ops man says and there's lots of opinions but I've used 10-30 oil year round for 40+ years without any issues, can't say if it will cause issues for anyone else or not . I don't use any fancy oils just change it when its due and keep things clean when checking /changing. Certainly not advocating that method but it's worked for me ! definitely think it helps on those cold winter days
Old 01-17-2018, 06:26 PM
Simply put, take care of your equipment and it will take care of you!
Old 01-17-2018, 07:43 PM
It doesn't.
Haha.
It's a hydrostat. We all know how those are.
I also put a trickle charger on it the day/night before I intend to use it. It sits in an unheated garage so it's out of the wind, but it still gets cold. I haven't yet gone the rear end magnetic heater (if it gets real bad) or the heat gun/hair dryer into the carb trick yet.
