Old 01-22-2018, 11:36 AM
goonpeden goonpeden is offline
Default PTO Belt
Hello Everyone! I just picked up a QA 42 Snowblower/Thrower for my 782 and wondering what the size or part number is for the PTO belt. P/O didn't have the belt or know the size. Looks like a 5/8 pulley on it. He had it on a 682. It's a bit rough from setting outside but after about half an hour and some WD40 and the grease gun spins freely! Any help will be Greatly Appreciated! Bill
Old 01-22-2018, 12:11 PM
sir_lancealot sir_lancealot is offline
There is a handy document in the tractor tech section of this site. Link is below.
http://www.onlycubcadets.net/forum/s...ead.php?t=4633
Old 01-22-2018, 12:51 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Lanceskene.....
The belts and blades chart link you posted in the Resources section is no longer where hosted.
If you still have the pdf, perhaps up load it to this site?
Old 01-22-2018, 12:59 PM
I just tried it and it works for me.
Old 01-22-2018, 01:11 PM
The QA42 is for a narrow frame Cub and will not work on a wide frame.
Are you sure it's not a QA42A??
Old 01-22-2018, 01:20 PM
Leadslingingdaddy's Avatar
Same here ... link worked fine..
Old 01-22-2018, 02:39 PM
DoubleO7's Avatar
Originally Posted by DoubleO7 View Post
Lanceskene.....
Well......I thought since this thread is about pto belt, Lance would look at this thread and see my related post.
The link in post #2 above works, yes.
When you go to the Resources section and see the thread in post #2 above, there is another thread about belts and blades created by Lance.
The link in his thread about belts and blades no longer works.
http://www.onlycubcadets.net/forum/s...ad.php?t=43944
I will just send him a pm.
Please excuse my posts in this thread.
Old 01-22-2018, 03:17 PM
Default PRO Belt
The ID plate is worn and scratched and the only thing I could read was QA42. But since I did mention in my first post it came off a 682 then it must be a QA42A.
Old 01-22-2018, 03:20 PM
Default PRO Belt
I just checked the Handy Link and found the belt number I need! Thanks to Everyone for the Helpful Info!!! Bill.
Old 01-22-2018, 10:15 PM
If you go up one thread from that one, you will find what you’re looking for. Link is here: http://www.onlycubcadets.net/forum/s...ead.php?t=4633
