Old 01-22-2018, 08:28 PM
Inactive Member
Default Driveshaft coupler
My 1772 has a driveline similar to the 2072. It’s converted over. So, last night I thought I’d go for a quick ride. Went to raise the blade and it quit. Moved the hydro lever and no movement. So this is what I found!
File Type: jpg 21196029-7D84-433A-BE90-5DE8B47B9A31.jpg (36.8 KB, 239 views)
Old 01-22-2018, 08:54 PM
I make replacement couplers if you want one. Both splined and smooth shaft pump input.
Old 01-22-2018, 09:02 PM
Inactive Member
This is a splined one.
Old 01-22-2018, 09:07 PM
I can't find a picture but I do make a splined one with the ball bushing
Old 01-22-2018, 09:37 PM
Found a picture of one "in process"
Old 01-23-2018, 09:22 AM
You mean it WAS a splined one LOL!!
Old 01-23-2018, 02:28 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
What does the male counterpart look like?
Old 01-23-2018, 04:50 PM
Terry C's Avatar
Terry C Terry C is offline
X2! Can’t be good enough to just put a new coupler on.
Maybe Jeff’s have more spline to engage “unused” splines IDK.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-23-2018, 06:14 PM
CubDieselFan's Avatar
I have one of the couplers that Jeff makes for the supers. I have not used it yet but I did a test fit and it will work fine when I use it. Mine was worn but not as bad as the op's.
Edit, the shaft was not worn any at all.
Old 01-23-2018, 07:29 PM
I make the splined section a little longer to get to the unused portion.
