Old 01-25-2018, 09:33 AM
Yes, the shaft is still available. Part #SU-3102989. Only $612.60 from Messicks.
At that price, we should stock up on a couple, three before the Chinese start making cheap knockoffs.
Maybe somebody needs to make a taper-lock to tighten on the worn splines like they do on the JD 2 cyl. flywheels.
Or do they, and I just haven't seen them?
I do know they make various taper lock pulleys for the 1-3/8" PTO shafts on farm tractors.
Old 01-25-2018, 10:03 AM
Originally Posted by IliketheRedcubs View Post
My hydraulic shop (near me) claims they can still get parts for the pump including the shaft. I'm not sure if I believe them or not... but they say these pumps are used in a lot of different applications.
Oh, they can. You have no idea how many this ued a U-15 Sundstrand hydro. Just get out the lube...... you can almost buy a new unit for the cost of a shaft and installation.
Like Todd said, about $600.
Old 01-25-2018, 10:29 AM
Replace the seal. Put some of this stuff or something like it on the splines of the shaft with a new couple from Jeff and Be Happy.
http://devconeurope.com/media/12553/...el-putty-a.pdf
Old 01-25-2018, 09:27 PM
I’ve messaged Jeff in the past about my 1782 and this issue. Mine also has an issue where the center bolt that threads into the shaft either fell out or wasn’t put back in as the threads are damaged and someone drilled and tapped the outside of the coupler for a 1/4 x20 set screw and installed it which mucked up the splines further than normal. Needless to say lots of movement and leaking seal because of it. $600 for the shaft ouch. Jeff’s price on the coupler is great and hoping the longer spline engagement will work in my case when I finally get time to tear it apart.
Old 01-26-2018, 06:42 AM
The 72 series uses a spirol pin to retain the coupler, the Cyclops use a bolt in the center of the shaft. For the Cyclops just find a used pump and use the input shaft in your pump. On the 72 series I would do the same thing and get rid of the spirol pin. Remember that the Supers have a different output shaft from the GT's.
Super reduction gearing 6.8 : 1
Reduction gear 68 Teeth
Pump Shaft 10 Teeth
GT reduction gearing 5.5 : 1
Reduction gear 66 Teeth
Pump Shaft 12 Teeth
Old 01-27-2018, 09:57 PM
Inactive Member
Latest update... Jeff sent me part of a coupler and when I put on the shaft it was tight! Now the bad news... I was looking over my driveshaft and thi is what I found... long story short, I’m going to convert to the CV driveline.
File Type: jpg 8735E4B1-98AA-44F4-8925-0E1CD9B67F00.jpg (21.2 KB, 59 views)
Old 01-27-2018, 10:34 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
one thing I've noticed about the diesels... they really beat on the driveline!
Jay
Proud owner of the following:
