Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-28-2018, 12:31 PM
twoton twoton is offline
Replace it with the largest CCA rated Battery, that will fit in your Battery Box.
...and clean up all connections. Look for stuff like this;
Old 01-28-2018, 01:43 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Also check the starter generator pulley. Had that seize up on me causing a hard start condition on my 124
-Rick
IH 782
IH 126
CCC 1863
Old 01-28-2018, 07:04 PM
JacksCubcadet124 JacksCubcadet124 is offline
Default one more thing
when i shut the engine down, it always backfires. Does that sound like a timing issue?
Old 01-28-2018, 08:15 PM
Could be. Could also be a fuel issue. Or a worn out muffler, or exhaust leak, or it could just be you aren't letting the engine cool down enough. Do you shut it off after letting it slow idle for a couple minutes??
I don't know if you found it or not, but the engine manual can be downloaded here:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Here's a thread on how to static time the engine:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Did you get the battery checked?
Old 01-28-2018, 08:40 PM
Default Thank you
No, I didn't know I was suppose it?
Thank you very much for the links. My battery is on a trickle charger and I plan to play with it after work tomorrow.
I'll keep you posted.
Old 01-28-2018, 09:39 PM
You should always let a motor cool a bit before shutting it off. More important on an air cooled engine, or a turbocharged engine than others.
Old 01-29-2018, 07:02 AM
I was learned
Old 01-29-2018, 08:15 AM
Good advise there! You wouldn't shut your car down at 3600 rpm, would you?
If you get yourself some allen head machine screws to replace the slotted ones for your points cover they will be alot easier to remove/install.
Old 01-29-2018, 07:54 PM
EXCELLENT idea
Old 03-21-2018, 05:21 PM
Default Another question -
It appears my ignition switch bad. How hard is it to replace it?
