Old 02-10-2018, 07:54 PM
Default Easiest way to clean walnuts in the shell
https://www.youtube.com/watch?v=wij0rKyTFsY
Although this works quite well, it's dusty and NOISY
Old 02-10-2018, 08:57 PM
john hall's Avatar
Looks fun Jeff! Try a free standing corn sheller sometime, that's what my dad said they used to do.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-11-2018, 09:39 AM
Spread 'em on the driveway and run 'em over with a Cub!!
Worked great for me last fall.
Leaves the mess outside.
Old 02-11-2018, 08:00 PM
Turn the handle and drop whole ears in? More bushels done by hand than I could count.
Roger doesn't have a cub but he cracks them inside ( basement ) during the winter
Old 02-11-2018, 08:57 PM
john hall's Avatar
[QUOTE=Jeff in Pa;446103]Turn the handle and drop whole ears in? More bushels done by hand than I could count.
Dad said they just poured/dumped in the walnuts to remove the husks. I never saw it done. The walnut trees were cut about 40 years ago, starting to die and one had about a 1 foot dia. rotten/hollow spot inside. I do remember enough walnuts on the ground to hold the lawnmower up. We still have the corn sheller.
2072 w/60" Haban
Old 02-11-2018, 09:08 PM
[QUOTE=john hall;446113]
I'll let Roger know that trick. ( I used the corn sheller for corn only )
His late Dad had a lot of vintage equipment and I'm sure there is a still a couple corn shellers on the homestead.
Old 02-16-2018, 11:24 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Dad and I also used the hand crank corn sheller to get the husk of black walnuts. Fed in one on top of another as fast as we could get them in, no hopper.
That was when we were going to crack them for our own consumption.
Then for a few years a local fruit tree nursery was paying us for them and paid if without husk.
We hauled them home by the 1973 International pickup truck piled as high as we dared.
Then jacked up one rear tire of the CC 125 and let the air out. Made a 2x6 with side boards into a ramp/chute of sorts under the spinning tire.
We shoveled walnuts onto the ramp/chute, nuts went under tire and shot out at a hunk of plywood propped up about 15 feet downstream.
Between getting squeezed and going splat against the plywood, the husk was off.
Old 02-17-2018, 10:46 AM
jimbob200521's Avatar
Had one of those in the barn growing up, it's what we used to do as well. Didn't work perfect but we had enough damn walnuts that we could stand losing a few if they didn't come out right
-Ryan
