#21
Finished putting the 1450 back together and took a final video. Need to adjust the hood latch, LOL.
Posted at https://www.youtube.com/watch?v=tQkenuyxuhc
That is a sweet looking rig Frank!
![]() Looks like you got the adjustment worked out for equal left and right on the cylinder? ![]() The modified (chewed) handle adds a nice touch! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#23
I do have a set of wheel weights to put on it, too. Just need to go get the bolts. I figured out the easy way to get equal right and left tilt--stop tilting to the right when it's far enough! ![]() It actually over travels to the right a bit. I measured the difference in travel at the blade ends and it's less than a couple inches, so it would only require a small adjustment. A half inch move in the rear pin would change the blade end to change by 2 or 3 inches. I'd have to cut that in half, a 1/4 inch move in the pin. So I figured it's not worth it at this point. Lots of my workbenches, cabinets, tool boxes, anything less than 3 feet off the floor and not made of metal, have chew marks. But all that chewing seems to fade away when the dogs are snuggling up to you and being affectionate. Wife says they will grow out of it. So there's hope.
This is not meant as criticism, and maybe its just the camera position, but it doesn't look like there's much lift on that blade. My 1641 lifts the bottom of the blade about 6" or so off the ground.
Mark 1641 |
#25
You are correct. I could put a shorter lift rod on it to increase the lift. Not sure it's needed, though.
Good Job. I have a dual 1450 and a 54 hydraulic blade. I believe that it has the factory cylinder mounting. For what it's worth it rotates further to the right than to the left. I have never really tried to diagnose it just though it was a little peculiar that it was that way. Now the rear mount was welded to the frame when I got t , but I believe the mounting bolts are in place.
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John"
#27
Frank:
Nice job.
#28
Hey Frank, how long are the hoses on this thing?
#29
Didn't keep a record of the hose lengths. Used a spare length of hose to measure the distances and wrote the lengths down to take to NAPA, but those notes are long gone.
