Old 03-01-2018, 07:54 PM
athomas's Avatar
athomas athomas is offline
I've used the rustoleum transport yellow, and the rustoleum almond not bad but seem to be a better match to newer Cub colors ,need something between almond and bright white ! I've heard that Krylon -dover white- may be a better match for the late 60's Cubs but haven't been able to locate any in stores to compare, like said earlier nothing like the right stuff in a gun with some hardener but a PITA to do a couple small pcs.
Old 03-01-2018, 08:05 PM
The Magic Paint is for the Magic Bus. Doesn't ever really set up, so the bugs love it. Thin, .....not a good match. The Van Sickle in the quart is good for the red '82 series, but the yeller is off a little. Still, it is a cheap alternative and holds up alright.
Old 03-01-2018, 08:54 PM
I have no problem with any enamel that comes in a quart,,,
Dump in the hardener,, they are all the same,,
This is Majic,
The paint is usually hard within a couple hours,,
if it takes longer,, I put the paint on too thick,,,
I also like Caterpillar old yellow,,, I get it at the CAT dealer,,,
Like I said,, they are all the same to me,, with hardener,,,
Old 03-02-2018, 07:50 AM
ironman's Avatar
ironman ironman is online now
Link to Amazon reviews for the Rustoleum Farm & Implement paint....
https://www.amazon.com/Rust-Oleum-74...ustomerReviews
Old 03-02-2018, 08:25 AM
goonpeden goonpeden is offline
In reply to Joe K, the Rustoleum Safety Red Professional rattle cans are not the same red as IH Red. It's a bit lighter in color, not as Deep Red as the IH Red. Still a pretty good looking Red. Once I get more familier with site I'll post some pictures.
Old 03-02-2018, 08:27 AM
I get the Rustoleum spray cans by the case from Home Depot, free shipping too!
Transport Yellow, $3.76/can
Old 03-02-2018, 08:57 AM
mickb72 mickb72 is offline
I really like the dover white color. A small hardware store stocked it where as the big box stores did not. That was a few years ago,need to see if they still do.
Old 03-02-2018, 02:16 PM
Terry C's Avatar
Terry C Terry C is offline
Which IH white? Seems to me that it’s almost a dead match match to 935 but not the other 2
I think almond is closer to all three than canvas white is. It’s not great for 01 and 02 but it’s closer than canvas white. If I had to pick one to do it all, I’d pick almond. Just my opinion.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-02-2018, 10:07 PM
budscub's Avatar
budscub budscub is offline
Default Navajo white
I have found that I believe it is Navajo white is realty close to the 902 white. I will have to go look at the can. I have the paint sanded down on my 125 so that each layer of paint shows. I then sprayed the Almond, and antique whites and found those to be on either side of the original paint. I then stumbled on some Navajo white. I will have to get a photo.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 03-03-2018, 09:06 AM
budscub's Avatar
Default Paint comparison
Got a couple of pics for yall. One is of a set of paint samples trying to match the IH 902 on a 125. The other is my newest treasure find.
The paint are all samples of Rustoleum rattle can. IT seems to be difficult to find the rustoleum in the quart cans in a very good selection.
The paint shown as original was exposed by sanding down to it with fine grit paper. I found it interesting that there was no primer from the factory.
Gary
1969 125 42"
