Old 03-14-2018, 10:13 PM
taylorjm taylorjm is offline
I'm not arguing....
But I've seen just about as many copper lines that didn't get soldered right as I have PVC fittings that didn't get glued right. Seen copper come apart, seen PVC come apart. One time, I saw a 90° copper elbow blow the outside corner, because the plumber didn't deburr the pipe after cutting. It was on a hot water circulation line, and the rolled edge caused cavitation to orrur in the elbow, eroding it out. That was a new one for me....
I've also seen pex fittings blow off, iron and galvanized rot out..... so, they all have issues one way or another, lol.
They sure do all have their pluses and minuses. Had a 90 blow off on a circulation line? Like, a boiler with a whole 15psi on it or a high pressure boiler?
Old 03-14-2018, 10:19 PM
No, the 90 didn't come off, the elbow eroded out and it sprung a huge gushing leak.
It was on a hot water line, as in hot water, not cold. House was huge, so the hot lines ran a circulation pump back to the tank to keep hot water in them at all times. No waiting for hot water that way. Only had to travel from the already warm line up the wall to the fixture.
Old 03-15-2018, 11:12 AM
Gotcha. I read it as the elbow blew off because the pipe wasn't reamed out.. couldn't figure out why that would happen. Caused a pinhole leak from not reaming it out, yup.
Old 03-15-2018, 11:34 PM
bocephus1991's Avatar
Ours goes out tankless is what we’re going to install!
Brian
