Old 03-31-2018, 09:51 AM
Nice work, I drove by your place thurs and friday, to the HH and saw you have a new showroom.
Did they build a new service center?
Up to 534 and counting...
Old 04-01-2018, 08:50 PM
John147 John147 is offline
No new shop we are still located in the back behind the building but the service advisors and customer contact point is now up there.
Old 04-01-2018, 08:52 PM
Back to the tractor stuff i got this column from lew, I rebuilt it new bearings, grease and follower.
I also installed a new water pump, bypass hoses and thermostat and flushed the cooling system.
Old 04-01-2018, 09:28 PM
Was the old water pump leaking?
Old 04-01-2018, 09:49 PM
No it wasn't, it would squeak very bad and it just annoyed me honestly. If i turn the pump in my hand it squeaks as well.
Old 04-01-2018, 10:01 PM
Odd. Maybe the weep hole was plugged....
Old 04-01-2018, 10:17 PM
Maybe or the seal just wasn't to that point yet but with it chirping/ squeaking it was only a matter of time.
Old 04-01-2018, 10:47 PM
I agree. I have seen bearings fail before the seal. It happens. Sounds like it was on the way out.
Old 12-10-2018, 06:52 PM
Well i've been doing more maintenance on the diesel.
I replaced the front hydro ports on the front so i could finally put my power angle kit on my snow blade and use it.
Then we started on the big issues. I replaced the PTO and installed a block heater. While doing this i also rebuild the fan bracket as one of the bearings i replaced a few years ago was making noise and replaced the actual fan this time and fan belt.
I also had to replaced the throttle cable and shut down cable.
Old 12-10-2018, 07:36 PM
Nice work John, what is next?
