Old 04-14-2018, 01:38 PM
Bluecub Bluecub is offline
Default 16hp K series
Hi guys, picked up a non running 16 hp out of a 1650 yesterday. Started tearing in to it today and found a bent exhaust valve, any recommendations on good replacement valves? Also the carb is in very poor shape and I don't think I'll be able to save it, are there any decent replacements that don't cost a arm and a leg? Thanks in advance !
Old 04-14-2018, 01:49 PM
How did the valve get bent?
Old 04-14-2018, 02:20 PM
Not 100% sure how but I have a good feeling that this little screw has somthing to do with it lol
Old 04-14-2018, 05:24 PM
twoton twoton is offline
Yup, that valve is screwed!
Old 04-14-2018, 05:51 PM
mortten mortten is offline
LOL
Ten characters
Doug
QA-36A
42" blade
Old 04-14-2018, 06:04 PM
taylorjm taylorjm is offline
That's where it went!
Old 04-14-2018, 06:22 PM
Originally Posted by Bluecub View Post
..... Also the carb is in very poor shape and I don't think I'll be able to save it, are there any decent replacements that don't cost a arm and a leg?.....
There's some talk about cheap china carbs here;
http://www.onlycubcadets.net/forum/s...606#post449606
But no links...
Old 04-14-2018, 07:34 PM
How do you know? That's a picture of the piston......
Old 04-14-2018, 07:38 PM
OP:
Only way I can see that the screw could have bent the valve is if it got caught between the head of the valve and cylinder head when the valve opened. What kind of shape is the head in?
I think you need more than just a valve. Seriously......
Buy the valve from this guy on ebay:
http://stores.ebay.com/The-Mans-One-...=p4634.c0.m322
There are lots of cheap carbs on ebay. Several members here have been buying them with good results. I have not bought any of them yet. I have lots of motors, and I just rebuild the carbs I have.
Old 04-14-2018, 09:41 PM
The head is ok, has one impression of the threaded portion of the screw. Nothing seems to be seriously damaged other than the valve. I've bought a Chinese carb
For a 10hp but it leaked gas out of every orifice lol, might have just been bad luck
Tags
16hp, carb, k-series, kohler, valves
