Old 04-13-2018, 11:31 PM
Keep us posted on your progress Sam.
Old 04-14-2018, 08:15 AM
Sam's probably about ready to open the pool, lol!
Get it working Sam! Grass is growin'!!
Won't be long, it was 75 yesterday. After playing with Pig Pen I did mow for about 2 hours with the 2264.
Old 04-14-2018, 05:09 PM
A before and after bath pics of Pig Pen. Looks like the seal behind the flywheel was starting to leak so that's on the to do list.
Old 04-20-2018, 07:33 PM
Parts on order. Should make a nice machine for someone when its all done.
Old 04-20-2018, 08:07 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Looking good and clean. Do you use steam or just a pressure washer?
Old 04-20-2018, 08:28 PM
Super clean and this.
Old 05-04-2018, 04:44 PM
Finally got off my lazy butt and replaced the seal behind the flywheel. Removed the throttle limit screw so now it's a CH20. Now to clean and repack the CV joints for the drive shaft and the tilt steering. Then on to rewiring and new gas lines. I removed the fuel shut off solenoid with the intention of cutting off the plunger but someone else beat me to it, LOL.
Old 05-04-2018, 10:09 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Please expand on this. Remove the throttle limit screw? That's two horsepower worth? And removing the fuel shut off solenoid... What does that do. Or better yet what does that prevent?
1- 1200 in pieces
1- 1864 in pieces
Old 05-04-2018, 11:46 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Sam has a good picture of the limit screw. It's right on the side of the carb. Only difference between the 18 and 20. So technically the 18 was more expensive because it had 1 more part.
The shutoff solenoid just prevents the engine from starting when it fails or doesn't have sufficient voltage to open when cranking. You can't remove it completely unless you have a block off plug. You just cut off the pintle and reinstall it.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-05-2018, 08:03 AM
Pic show the limit screw and fuel shut off.
