Old 05-13-2018, 08:21 AM
Induxin Induxin is offline
Default 129 Brakes
Just got this 129 a little while ago, the engine had some problems but was fixed right away. After using it for another day or two, i noticed the brakes went working and it was stopping entirely by force of the Hydro. After a good look under, we found the problem is that these arms are locked up, any idea on how to free them?
Old 05-13-2018, 08:26 AM
john hall's Avatar
Most of the time a hydro will stop by the transmission/hydro unit before the brakes can even think about being activated/having time to stop it. I think most hydro machines have rusted up brakes because nobody ever mashes the pedal down unless cranking (safety switch) or locking brakes for hauling. I don't know the set up on a 129, but our 128 has external brakes on the end of the axles--so I would imagine yours is the same. I have ran into a 782 and a 1811 that the brakes required disassembly so everything could be freed up proper. Don't know about yours but be careful applying heat if you have cast aluminum compnents--you don't want to know how I figured that out.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-13-2018, 09:09 AM
First, welcome to OCC.....
PB Blaster....
Old 05-13-2018, 09:34 AM
PB Blaster....
I've tried WD-40, will try PB blaster
Old 05-13-2018, 09:52 AM
PB Blaster is 10 times better than WD40. Spray on the "moving areas" allow to soak for 5-10 minutes, then work the parts free. Re-peat as necessary.
Old 05-13-2018, 09:54 AM
Kroil is better than PB....but costs about 4 times as much....maybe 5 times.
Old 05-13-2018, 10:11 AM
Bob95065 Bob95065 is offline
+1 on Kroil. The downside is the price but there is no substitute.
Old 05-13-2018, 10:40 AM
Kroil stinks awful,but works great
WD 40 is WD = water dispersant ) not a penetrating or lubricant oil.
Old 05-14-2018, 08:28 AM
TOPDOWNRESTO TOPDOWNRESTO is offline
try 50/50 ATF and acetone. Has worked better than any penetrant Ive ever used. Cheep too . A quart of each will yield a 2 qt mixture and last a loooong time. Acetone draws the ATF into the deepest ,rustiest areas.
' 68 125 '75 1650 dual stick
