Old 06-02-2018, 06:17 PM
baldy347 baldy347 is offline
Default 2186
Just picked up a 2186, and I'm having a time trying to date this thing. Sticker on the right hand frame rail lists serial number as 1F244G10058. I've tried searching here and on the web. I must be doing something wrong as I've had no luck.
Many thanks, Wayne
Old 06-02-2018, 08:26 PM
It was made between 2000 and 2003. Is the exact date important for some reason?
Old 06-02-2018, 09:46 PM
No particular reason, simply curiosity. Thing seems to run well,transmission appears to be good but service lacking ; both trans filter and oil filter dated 3/14. Air filter nearly plugged.
Many thanks for the help,
wayne
Old 06-03-2018, 08:20 AM
Well, Tractor Data shows they were built from 2000 to 2003 (as Jon said) but if you break down the Cub Cadet serial number here is what you get.
1 = engineering rev 1
F = June
24 = day of the month
4 = 2004
G = Brownsville, TN plant
1 = assembly line 1
00058 = 58th tractor of the day made on assembly line 1
What info is on the engine?
Old 06-04-2018, 11:15 AM
Can't find a data tag for the engine. It is a V-Twin, but no easily visible name tag as to make or model. Air cleaner cover is marked Cub Cadet.
Old 06-04-2018, 11:32 AM
The 2186 rolled out of the Factory with a Kohler Command Engine - #CH18-62588
Old 06-04-2018, 03:26 PM
I am hoping that is what is in there now, it does run well. rest of the tractor leads me to believe that the hour meter has not worked for some time; shows less than 400 hrs.
Many Thanks,Wayne
Old 06-04-2018, 03:35 PM
TNTs CC TNTs CC is offline
Got pictures?
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 06-04-2018, 04:04 PM
Have a few,hopefully doing this right. some how i am screwing this up
Old 06-04-2018, 04:12 PM
I will need to wait till a Grandkid gets here...
