Old 06-07-2018, 07:44 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Default White Build-up in Exhaust
I took my muffler off my 147 to fix an exhaust leak, and noticed this white build-up inside. Is it normal or anything to worry about?
I could try to get better pictures if these are not good enough.
Old 06-07-2018, 07:50 PM
cooperino's Avatar
Looks like she been running a tad lean. how does the plug
look?
Old 06-07-2018, 07:59 PM
I probably should have mentioned that I put a new spark plug in about 4 months ago and that one had a build up like that. Here is a picture of the one in it now.
Old 06-07-2018, 08:13 PM
cooperino's Avatar
can you post a picture of the end. Center electrode?
Old 06-07-2018, 08:22 PM
Is this any better?
How often are you adding oil to it?
Old 06-07-2018, 08:25 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Looks like your DEF nozzle is leaking!
Seriously, looks like you're burning some oil, and hot! Have you checked the timing? Tuned the carb? Checked the head gasket?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-07-2018, 08:35 PM
I have to add oil almost every time I use it.
I have not checked any of that stuff, but I'm guessing I should.
Old 06-07-2018, 08:48 PM
That's what I figured. Oil burner.
Might be a tad lean, but it looks more like you just use it and get it hot while working it. Not much you can do short of an overhaul. I'd still make sure the carb it tuned right. Itherwise, put it back together and run it until you can get a new motor.
I build them by the way....
Old 06-07-2018, 09:10 PM
I'll check the carburetor and keep using it. I want to get it rebuilt eventually.
