Old 06-16-2018, 06:56 PM
jjardina jjardina is offline
Default 129 Belt madness
Hi, quick or not so quick question...
I have an IH Cub Cadet 128 with a 44 inch deck. The belts are in really bad shape, so I decided to order some online after looking at the belt/blade and pto reference guide. The generator/starter belt went on fine, although 30" seems kinda small, starter/generator is almost up against the engine, but it works, 32" would've been perfect.
The real problem is the PTO belt. Well, something is screwy either in my order or my reading comprehension, I received a 1/2" by 103" belt, but the one I took off appears to be approx. 81".
Can anyone please tell me the part number that I should order for an ~81" belt to go from PTO on 128 to a 44" deck.
Oh, yeah, my mule gears are angled toward the center of the mower, so it is the correct mule. Someone had asked me that on my hello post.
Thanks in advance,
Jason
Old 06-16-2018, 07:18 PM
Bamafan Bamafan is offline
Inactive Member
If you go to the cub cadet parts web site or the partstree web site you will find the part numbers you need. Pretty simple.
http://www.partstree.com/parts/cub-cadet/
http://www.cubcadet.com/equipment/cu...vice-and-parts
To save you some $$ the belts are cheaper if you search the web E bay ect.
[B]Larry[/B]
Old 06-16-2018, 07:35 PM
Go to this link and D/L manual. Look on Page #41.... Mower manual
Old 06-16-2018, 07:41 PM
Thanks, but none of those really helped at all. The first link doesn't specify the belt part number and the second link doesn't have a belt for 44" deck.
The wife decided to get scientific and measure it with a piece of cut string. It is exactly 80". I googled 1/2 x 80" cub cadet belt and received the following part number:
954-3037
I am going to order that and I should be in business. I will probably sharpie it under the engine cowl so I don't have to go through this mess again.
Old 06-16-2018, 08:12 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
The belt for that tractor should be 3/8 not 1/2
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 06-16-2018, 09:09 PM
athomas's Avatar
athomas athomas is offline
Chart say's should be this one ( IH-59971-C1-3/8 X 78"), if the 44 inch deck has the correct dia. center pulley ? http://cubfaq.com/belts.html
Old 06-17-2018, 07:37 PM
Woah! That link is awesome and just what I needed. Thank you athomas! I am printing that page off and putting it with my documentation. Obviously, previous owner put the wrong belt on the mower. Thanks again!
Old 06-17-2018, 09:06 PM
athomas's Avatar
Hope it helps ! I think the center pulley correct for the 44 inch deck on a 108 would be about 5 inches ? the later 44 inch decks had a smaller dia pulley and a wider belt I believe, not real familiar with the 44/44A/44C decks just getting into them with the 149 I'm currently working on !
Tags
128, belts
