Old 06-30-2018, 11:48 AM
jonnb33 jonnb33 is offline
Default Cub cadet 3184 charge pump
I have a 1999 3184 with a charge pump that has exploded. I can't seem to get the correct gerotor for it. Does anyone have any idea where I can find a new or used one? Hydro Gear BDU-21L-501
Old 06-30-2018, 03:26 PM
CubDieselFan's Avatar
What is your serial number? The parts look up shows two options.
Old 06-30-2018, 03:36 PM
Thought Lew was sending you the Technical Bulletin addressing your issue.
Old 06-30-2018, 03:46 PM
He might not have seen that, a lot of good info in his other thread, that had too much chit chat, got deleted.
Old 06-30-2018, 04:25 PM
I did send it, only one page that describes the old part numbers being continued, and the new part numbers that replace them.
He needs the old part number which is nla.
So he either buys a new pump at 1700.00 or finds the old style pump gear.
Here is a link to the S.B. https://drive.google.com/file/d/1wYv...ew?usp=sharing
Old 06-30-2018, 04:45 PM
Did you contact any of the Sponsors listed at the top of the page..???
Old 06-30-2018, 10:49 PM
ejl6658 ejl6658 is offline
Patton Acres which is one of the sponsors has a used charge pump from a 3240 for $115.00.
Old 07-01-2018, 12:43 AM
1f190g20027, 3184, 14a-634l100, hydro-gear bdu-21l-501,thanks
Old 07-01-2018, 01:26 AM
Both the 3184 and the 3240 use the "same" hydro unit.........618-3214
Old 07-01-2018, 09:12 AM
Two options same part number
