Old 07-04-2018, 04:41 PM
jpw1400 jpw1400 is offline
Default Stripped aluminum oil pan
Drain plug on my aluminum oil pan (from a 1450) is stripped, and I'm rebuilding engine. Everything I read is to replace the oil pan with a cast iron one, but I'm having trouble finding one that's not aluminum. Does the cast iron one have a different part number, or is the deep sump not necessary?
Thanks for any tips.
(And for those detectives out there, yes, the stripped oil plug is why I am now rebuilding the engine. Turns out they don't run so well without oil.)
Old 07-04-2018, 04:51 PM
Yes, the cast iron pan uses a different part number.
Yes, the deep sump is necessary. If you use a shallow sump, you will rebuild it again after you start it and break the dipper off the rod.
You can find a CI pan on ebay.
Old 07-04-2018, 05:20 PM
sawdustdad's Avatar
Helicoil or drill and tap for a larger plug. Helicoil all the mounting bolt holes while you are at it.
Old 07-04-2018, 08:29 PM
I have a couple cast pans. Pm sent.
Tags
aluminum, cast iron, stripped
