Noticed yesterday mower was mowing in reverse even when pto switch was pushed in.
After about one minute blades would stop turning. Hope is relay, but any suggestions on fixing problem is appreciated Thanks, John |
It mows in reverse when the PTO is on? Or when the PTO is off? If all you are saying is the PTO does not cut off in reverse like the safety system is designed to do, I'd say congratulations. Don't worry about it.
![]() Quote:
![]() Most people take the time to bypass that safety! Your tractor did it on its own.. Jon is right.. Congrats!
Mowed in reverse with pto switch pushed in. Blades will stop turning after about one minute
Have concern pto will not work at worst moment |
![]() Quote:
You mow backwards for 1 min? Or when you go forward again, they cut out a minute later after backing up? |
![]() Quote:
If its when you shift forward to reverse, It could be that the switch is hanging up for the reverse pedal.
pto off blades keep turning
If the PTO is off and blades keep turning, it is either a bad PTO switch, or a shorted wire from the switch to the PTO. I looked at the diagram, and the wires run from the switch directly to the PTO. If the switch is "off" then the PTO should be off no matter what.
![]() Quote:
I really need replies from the OP, not you, to help him find a solution. I can read what he wrote just fine, thanks.
