Old 08-02-2018, 02:29 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Side panel screws
Made some screws for my 1250 side panels. Thumb screws, couplers, T-nuts and red Loctite. Makes it easier to get to the fuel shut-off valve.
Randy
Old 08-02-2018, 02:31 PM
Why would you need to get to the fuel shut of valve that often?
Most hardware stores carry wing nuts and bolts....
Old 08-02-2018, 02:50 PM
cooperino's Avatar
I like it! Anything that makes life a little easier is a good thing!
Old 08-02-2018, 03:20 PM
hyperlightboards48 hyperlightboards48 is offline
Cool, the panels seem to have to come off as quickly as I install then back on. Especially while I continue to iron out kinks. This would make the removal that much faster.
Tanner
Old 08-02-2018, 08:24 PM
bllwnkl's Avatar
I shut it off every time I'm finished with it.
Yes they do. That's where I got these. I wanted something one piece, the right length, and something so I didn't have to deal with washers. This is what I came up with.
Randy
Old 08-02-2018, 08:25 PM
Why?
Do you shut the gas off on your truck when you put it in the garage?
Old 08-02-2018, 09:04 PM
I always shut the fuel off on the 784 but i added a shut off right before the fuel pump so all i have to do is lift the hood. I once had a Cub that developed a pin hole in the float and it emptied a full tank of fuel on my shed floor, sure wish i would have shut the fuel off on that tractor, took forever for the smell to go away.
Old 08-02-2018, 09:21 PM
bllwnkl's Avatar
Why?
Why? Because with a gravity fed fuel system there is constant fuel pressure on the carburetor if there is fuel in the tank. There may be a week or even longer between mowing times. I've walked in my garage and it reeked of gas. The pressure forced gas out any orifice it could find. So, I now shut it off and run it dry and haven't had that problem since.
My truck? It's not gravity fed.
Randy
Old 08-02-2018, 09:27 PM
twoton twoton is offline
Nice setup there Mr wnkl.
I shut my fuel off too.
But what do I know. I clean my spark plugs too.
Old 08-02-2018, 09:34 PM
It only leaks if the needle valve in the carb is bad. Put in a new one, and leave the gas on. Easy fix, and no need to take the panel off all the time. Really no need to change the tractor over a cheap fix.
