Old 08-19-2018, 10:25 AM
Ummm,....snow thrower
Old 08-19-2018, 10:34 AM
scgtguy's Avatar
scgtguy scgtguy is offline
Thumbs up blower
folks ... tks for the input ... ill watch some of the vids and start doing a little research ...
rgds, B
Old 08-19-2018, 09:47 PM
Gompers Gompers is offline
The QA-42/36 work fine. They don’t seem to like the end of driveway stuff very much though.
I put mine (qa-36b on a 782) through some stuff that the neighbors 2 stage walk behind wouldn’t touch last year sloppy (city plow had pushed the slop out of the street and onto the sidewalk) and it moved it about 6 feet off the sidewalk. Did the job I suppose but it was none too impressive, especially compared to my old 2 stage Toro walkbehind. The chute plugged up a few times too when it got a little too sloppy as well.
They blow powder and “regular” snow great though. Even heavier wet stuff, though not as well. 2 stage is definitely an improvement, but I’d give a 42 or 36 a shot first. You can snag them for like 100 bucks and worst case scenario you have to sell it on.
Old 08-19-2018, 10:13 PM
I think the bigger problem is Cub Cadets and attachments are few and far between in Montana.
Old 08-19-2018, 11:15 PM
Everything is few and far between there! that’s why i meant to suggest he snag one before he heads out just in case. Worst case he’s out $100 bucks for a thrower that doesn’t work well enough.
Old 08-20-2018, 12:02 AM
Yeah, I get it..... but once he gets out there, if he doesn't like it and wants to sell it.... who's going to buy it? Unless he ships it....
Old 08-27-2018, 09:06 PM
scgtguy's Avatar
Default blower
howdy,
been doing some research ... would like a 450 but I see estimates of 175ish lbs and appears that considerable weight is required to counter balance ... also the issue of harder steering with that beast up front. I would also have to adapt it to my 1450 ... altho I believe my transplanted 20hp vanguard would have enough oomph...
It looks like the QA series blowers would be much lighter and easier to handle ... also from vids I've watched looks like loading tires / and or wheel weights with chains make enough weight for traction ...
any gustimates for weight on the QA's out there ? ...
B.
Old 08-27-2018, 09:25 PM
Originally Posted by bugeye View Post
In NW Montana, I would guess the snow is pretty dry. A snowblower will blow a long way. You will learn about wind direction and which way to blow the snow and how high. A cab will be beneficial as the blowing snow in your face gets cold and old quickly.
Full face motorcycle helmet works great if you don't have a cab. Crack the visor open one notch and "Bob's your Uncle"
Hard packed snow takes a different approach with a single stage snow thrower. One you get a full width, then just take enough to throw. No problems
As far as weight of a QA42, probably 150-175 lbs
https://www.onlycubcadets.net/forum/...ad.php?t=37251
I like the QA42 on my 125, it works quite well.
https://www.youtube.com/watch?v=tfWy8jbj_GY
It will throw wet snow but not near as far. I use a generic "PAM" cooking spray on the chute so snow doesn't stick
Old 08-27-2018, 09:39 PM
scgtguy's Avatar
Default 125 with QA-42
Jeff ...
tks for the vids and info ... watched the vid .... couldnt see what you have on the rear wheels for weight and I assume chains .... looks to move thru the snow well. Whats the height of the QA ? think it will eat thru 1.5' of snow ?
rgds, B
Old 08-27-2018, 09:50 PM
Originally Posted by scgtguy View Post
Jeff ...
rgds, B
I try to get out before it gets 1-1/2 feet deep. Taking small "side bites" after a full width path, I've been hood deep in snow. Going DOWN HILL, up hill that deep doesn't work well.
I have fluid filled 8.50s and four link chains. Two links would be better. No additional weight other than my 220 lb frame The front tires NOW are tri ribs 4.80-8 ( in video they are factory 4.80-8 ) and the tri ribs steer better.
I have two 125s and previously used the other one with 10.50s fluid filled and the wide 6.50 -8 front tires. That went well too but the skinnies steer better.
I do have a pair of 65 lb Gilson wheel weights that I can put on. ( shown on the manual lift 125. The hydraulic lift 125 is in the video )
