I'm thinking about restoring this 682 I have sitting in my garage, the other half of my two-fer pickup a few weeks ago, and swapping out the non running KT17 Series 1 with an extra Magnum M18 (with wiring adaptations for the different ignition system) I have if I can get it running.
20180804_003444739_iOS.jpg But I don't know if I'm going to. EVERYTHING is rusted on it. The worst of it is the lift handle button on top is rusted tight, I keep soaking it with PB Blaster and letting it soak for days and then tapping it with a hammer and it hasn't broken loose yet. I think the rust is all the way down inside, and I may never get it freed up. I do have a question about the rear though... The main part of the rear is cast iron, but the axle tubes don't look like the other cast iron rear I had from a 149 or even the 73 I have currently in my driveway... They look like aluminum. Did IH use a cast iron rear and aluminum axle tubes at this point in production?
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
![]() You could also cap one end of a 3 foot long piece of pvc pipe and fill that to soak the whole thing!
I have a 1450 that came with a cast differential and aluminum axle tubes. Swapped out the aluminum tubes for cast ones.
72,147,149,169,1450w/Johnson loader,#2 cart, IH lawn sweeper |
