Old 08-31-2018, 04:16 PM
Originally Posted by cooperino View Post
So I am trading one of my 44A decks and a carriage this weekend for a complete 104 tractor . Since I am loosing a 44a and I have one ready to be fixed up I started on this one today. Over all it is pretty solid. All the spindles seem good but I will go through them anyway. I have all the covers and parts for it.. Heres a few before pics.
Holler if you need any paint tips.
Old 08-31-2018, 05:26 PM
cooperino's Avatar
Yes um.. I'm told it's best to wipe down with some oil before painting.. is that good? Lol
Old 08-31-2018, 06:34 PM
Keep us posted on your progress.
Up to 534 and counting...
Old 08-31-2018, 06:47 PM
cooperino's Avatar
I will lol, However. Im gonna paint this with white I already have in stock because Im just gonna stick it on a tractor and cut grass with it. Hope the correct police don't arrest me
I will do a restore on a cub soon tho with correct colors and such. Maybe over the winter.
Old 08-31-2018, 07:23 PM
Oil works great, it really helps the dirt stick to the panel.
Old 09-01-2018, 10:04 AM
cooperino's Avatar
On the underside I definitely will use Por-15 or similar. On top of that I think I might use Rustoleums Aluminum. I used it once on a flatbed wrecker I had and could not believe how tough it was. Dragging cars and trucks up and down, some with no wheels and wrecks barely scuffed it. It sprays on really smooth and gets super hard. Topside will just be rusty metal primer and some single stage white I have hanging around. Maybe paint the guards yellow.
Old 09-01-2018, 09:43 PM
IHCubCadet147's Avatar
I pulled the motor out of my 129 to fix two mounting bolts that were broken off.
Old 09-04-2018, 02:35 AM
yachtwork yachtwork is offline
Default Head gasket
I pulled the head off my 127 K301 for a blown head gasket. I put the head on a piece of 320 sandpaper over glass and made it smooth. It was warped for sure. Put it all back together and am listening to it run for a half hour so I can retourqe the head and see if this time it holds. This is the fourth head gasket replacement counting the blown gasket I got it with.
Old 09-04-2018, 08:28 AM
If you never resurfaced the head before then that's likely the reason it kept blowing, hope it holds for you this time.
Old 09-08-2018, 11:15 AM
TheFlyingCub TheFlyingCub is offline
Over the last few days: stripped, primed, and painted all the engine tins and block for my donor 12hp for my 105. Also pulled the fenders, rear trim plate, seat mount and a few other parts and did the same to those too.
Watching a pile of rust turn into that beautiful yellow will never get old. Promise I'll try to take enough pics to make a restoration thread on this one!
Have a great weekend all.
1970 147
