Old 08-29-2018, 08:08 PM
I use a hamma'
Up to 534 and counting...
Old 08-29-2018, 08:18 PM
I use a hamma'
That's more what I was thinking.....
Old 08-29-2018, 09:09 PM
Yeah, the Ralph Cramden method I call it.
Hamma na hamma na hamma na.
Old 08-29-2018, 09:22 PM
cooperino's Avatar
This really burns my brass buttons!
Old 09-02-2018, 10:11 AM
sorner's Avatar
sorner sorner is offline
PTO works fine, it was operator error. The problem was between the seat and steering wheel.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 09-02-2018, 01:29 PM
So.... did you and the owner neither one know how to operate this machine? What exactly is supposedly wrong with it?
Hard to fix something if you don't understand how it works in the first place.
Old 09-03-2018, 07:12 AM
sorner's Avatar
I wasn’t fixing the PTO. The engine wouldn’t start after a heavy rain storm and it spends all its time outside. There was water in the gas tank and in the points cover so I cleaned it all out and it runs great. The thing with the PTO is I thought I knew how it worked and I was wrong. All I had to do was look at the dash decal but I overlook the obvious sometimes.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-03-2018, 07:23 AM
cooperino's Avatar
Overlooking the obvious happens. We all do it sometimes. Well most of us.. We are after all human.
Old 09-03-2018, 07:48 AM
titleist1 titleist1 is offline
Well....most of us.....
Old 09-03-2018, 10:11 AM
The fuel tank on a 73 is under the hood and protected. Did he leave the hood open too?
So.... you didn't read the dash decal. Did you try moving the lever into both spots? Or did you just shove it forward, then assume it was stuck since it was running, then go running inside to your computer to ask us how to fix a stuck PTO?
Sorner.... you work on this stuff all the time. All as I expect from you is some thought. Maybe try a few things. Look in a book.... maybe even take a look at a dash decal... before running to the PC and getting the hive stirred up. It's not that people here don't want to help, it's more about calling wolf all the time. Stuff like this happens with you a lot it seems. This is why when you come on here and want to know how to fix XXX, it makes me wonder if that is really what's wrong, or if you have any idea what is. You really need to take more time trying to figure stuff out before running to the forum. Sure, we miss little things sometimes.... but you kind of missed the elephant in the yard here man. All you had to do was try the lever in the other position. Or read the dash. Or even look in a book. You did not need to start a thread. Next time you post, don't be upset if we ask you all the painfully obvious questions first before we give you any advice.
