Old 09-09-2018, 09:09 AM
CabinCub2002's Avatar
CabinCub2002 CabinCub2002 is offline
Talking IH Cub Cadet 102
Hello
I live in New York State in Penn Yan but my family has a cabin in Filmore NY. We have a International Harvester 102 from 1967 I believe and I have been working on it ever Friday evening and every Saturday at the cabin since about August 10th of this year.
So far all me know is the tractor engine is working OK just the carburetor won’t supply fuel to the engine. Also I forgot to say the tractor has been sitting for 10 - 14 years so we are trying to get it running again. We have changed all the fluids and and are now getting new gaskets for the carburetor. Also might I add that the tractor did have a snow thrower that my grandparents are going to get rid of and set of the curb of their house in Syracuse New York.
I have enjoyed working on the tractor and hope I can get it running again so my grandparents don’t have to buy something new for the cabin. I really like the tractor. So that’s about it for what I have to say.
Old 09-09-2018, 09:15 AM
cooperino's Avatar
First off welcome to OCC!.
after so long sitting I would suggest removing all fuel related items and cleaning thoroughly. Tank, carb, new lines, clean fuel bowl etc.
Here to help along the way! Good luck
Old 09-09-2018, 09:24 AM
Thanks and that’s what the plan its tank is already cleaned out same with the fule line due to being gravity fed we are going to pick up carb cleaner to so that might do the trick
Old 09-09-2018, 09:30 AM
cooperino's Avatar
You will likely need to disassemble the carb and clean internally. I usually soak mine for a couple days in diesel fuel and acetone mix. If you have never cleaned a carb there are very affordable after market carbs readily available for around 25$
Old 09-09-2018, 09:33 AM
cooperino's Avatar
BTW we love pictures here hint hint
Old 09-09-2018, 09:48 AM
Default I bet you guys do enjoy the tractor pictures
And I have never cleaned a carb before but I got similar advice from my friends who works on small to medium gas engines a lot. Also I just posted 3 pictures in album I will get more when my grandparents post things of me working on the tractor.
