Old 09-09-2018, 11:21 AM
BTC1984 BTC1984 is offline
Default 1730 governor spring
I put on a new carb. Everything seems to work fine. But there is this spring that I’m not sure if I put back in properly. You will see in the photo, the green arrow is correct, but the other end, the red arrow does not seem to be connected to anything. Any ideas ?
File Type: jpg 0C9EBEA4-B479-4A15-9C04-591FB054E089.jpg (25.1 KB, 36 views)
File Type: jpg C3D2968E-1F3C-4BA3-89E5-4021ACE9E93D.jpg (29.1 KB, 36 views)
Old 09-10-2018, 02:17 PM
Chad126's Avatar
Chad126 Chad126 is offline
Appears to be some sort of torsion spring and I think it is p/n KH-52-089-08. Look that up and see what you think. I could be wrong, but maybe that will give you a starting point.
Any chance you can take another picture of the end that isn't connected to anything? Is that "loose" end bent or does it have a foot on it?
And this might be a good question to post in the LT section. You will likely get more responses there.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
