- I already essentially did Test 2 and get 47-48V. Comments here are that is too high, but the test states that anything above 28V is passing so I'm not sure how to interpret this. - I performed Test 3 and got 0.1-0.2 ohms on my meter. That seems to be a pass. My meter only reads out to xxx.x, not x.xxx, so I would not be able to read out 0.064. But it definitely was not open line (OL). - I performed Test 4 on both AC leads and my meter read O.L. As far as I know, that is the same as infinite resistance. If that is true, that test seems to pass. The link seems to be a graphical explanation of Test 3. I will redo all of this tomorrow when I have more time, but wanted to get a response back. Tomorrow I'll set up a ground wire, right after I replace a bad fuel line that suddenly started leaking. Thanks! |
