Old 10-05-2018, 04:17 PM
Tom Dowling Tom Dowling is offline
Default KT17S with 3 serial numbers...which is correct?
My 682 has three serial numbers in a group on the motor shroud. Is there another place with numbers?
File Type: jpg Burst_Cover_GIF_Action_20181005145251.jpg (24.5 KB, 112 views)
Old 10-05-2018, 04:31 PM
I only see 2 serial numbers, but 3 tags.
Likely, it was replaced at some point. The big tag on the side is the newer tag. New engines didn't always come with tins, but would have came with a serial tag.
Old 10-05-2018, 05:14 PM
This is what you have:
M/N: KT-17S Series II
Spec No: 24302
S/N: 14005601
Which rolled out of the Factory, in 1984.
Old 10-06-2018, 09:56 AM
I figured you all would know, thanks.
Old 10-06-2018, 10:17 AM
We gave conflicting info though..... so which tag are you going off of?
Old 10-06-2018, 10:57 AM
I'm going with the big tag on the side
Old 10-06-2018, 04:17 PM
ironman's Avatar
ironman ironman is offline
From the Kohler KT Series Service Manual.....
Old 10-06-2018, 04:37 PM
Yes..... that's correct. But if the engine has been replaced (highly likely) the new engine would have came with a new serial number and a new tag, which appears to have been placed on the tin just below the original serial number. So, the lower big tag would be the new SN.
Old 10-06-2018, 09:29 PM
Gompers Gompers is offline
Looks like the newest serial number you have there is from 1988 (18xxxxxxx). So it's likely that your engine was replaced with one about 4 years newer at some point.
It kinda stinks that the only place a serial number for these engines exists is on the tins. They get swapped around after rebuilds and replacements and you can never quite trust them.
Old 10-06-2018, 10:00 PM
I agree.
Serial number isn't really all that important anyway. Seldom do you need it. Spec number isn't a big deal either if you know the application, but it's more important than the SN because it gives the build.
