Old 10-09-2018, 03:06 PM
ibohunter ibohunter is offline
Default Air filter cross over
I have a XT2_LX46 with the EFI 679 engine with the air filter number 937-05075, what other Brand filter will fit, thanks in advance, JIM
Old 10-09-2018, 03:17 PM
cooperino's Avatar
Is there some reason you dont want to use the OEM? They are available easily online. Also most decent mower shops carry that filter as well. I would not be shocked to find it in Home depot or lowes either.
Old 10-09-2018, 03:25 PM
Was looking for something of less money, FRAM< WIX ECT
Old 10-09-2018, 03:28 PM
cooperino's Avatar
Amazon is 17 bucks... I don't see one cheaper than that
Old 10-09-2018, 03:35 PM
cooperino's Avatar
Have a look at this to see if its the one you need.. Its a whole tune up kit for under 20$
https://www.amazon.com/Panari-Crafts...679+air+filter
Old 10-09-2018, 04:04 PM
Mine is the round one
Old 10-09-2018, 04:08 PM
can't find the 937-05075 filter on Amazon
Old 10-09-2018, 04:11 PM
cooperino's Avatar
Ill have another look later. I think there is probably a kit available like the one I showed you with the correct filter.
Old 10-09-2018, 04:22 PM
The possibility exists, that there is NO aftermarket filter for this application. OEM maybe the only option.
Old 10-09-2018, 06:22 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
That is an easy one.................
Any brand with the same dimensions will fit.
