Old 10-23-2018, 12:01 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Default 123 Tie rod
Long story short: previous owner must have ran in to something, messed up the steering knuckles. He sort-of fixed it, but it has never been right.
I think one or both of the steering knuckles are tweaked, not sure which. But I think I could make a decent repair if I knew the length of the tie rod that goes between the knuckles... part number IH-384632-R1.... (I am not at the tractor at the moment to measure). I might be able to fix it OK with a tie rod that is an inch or so longer than original. Currently, the tie rod ends are holding on to just enough threads to keep them on.
I will also try to straighten the knuckle(s).
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 10-23-2018, 10:10 AM
sawdustdad's Avatar
The best fix is to repair the steering knuckles and keep the tie rod stock. If not feasible, maybe make or get someone to make a tie rod extension? Or make a new one from rod stock...
Old 10-23-2018, 11:01 AM
nra1ifer's Avatar
Thank you.
Any idea where I should look for parts? I would rather fix it right.
nra1ifer
Old 10-23-2018, 12:17 PM
sawdustdad's Avatar
Any of the forum sponsors, or, ebay. Or local CL ads. Or post on the wanted section of the forum.
