Old 09-07-2015, 05:29 AM
twoton twoton is offline
Thanks guys, I knew I could count on you all for some great advice!
And happy Labor Day!
Old 09-07-2015, 08:08 AM
cubs-n-bxrs's Avatar
I have an Auto-Arc made by Hobart. It has adjustable darkness, adjustable delay and a switch for grinding or welding. It wasn't overly expensive but suits it's purpose.
Old 10-29-2018, 08:24 PM
As a little add on to this, in addition to the Lincoln helmet that I got I added a cheater lens;
https://www.amazon.com/dp/B07BVYMZN3...v_ov_lig_dp_it
Sure helps to see what you're doing.
Old 10-29-2018, 08:30 PM
john hall's Avatar
Dang, bifocals for the welding helment
Seriously, that is NOT a bad idea--for those of us with enough birthdays to now own a pair of "shop" glasses--I just couldn't stand the thought of bifocals and turning wrenches.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-29-2018, 08:53 PM
Farmall450's Avatar
I have a Jackson Nemesis and a Hobart. Both autodarkening. Mostly use the Nemesis now, way better sight. Grind mode is OK, too.
Old 10-29-2018, 09:05 PM
I have a 2.5 cheater I put in my Jackson auto darkening helmet when I weld a motorcycle tool I make. I weld a 1/4" pin on the end of a threaded 10mm bolt. One stray TIG arc makes for extra work to fix the threads.
Old 10-29-2018, 09:18 PM
Billy-O's Avatar
Billy-O Billy-O is online now
I have a Forney auto darkening. Range settings are 9-13. This was a gift. Prolly came from TSC. I used it a few times. It was a wonderful weldimg experience compared to regular old fashioned lens. It also worked great during the solar eclipse last year.
Plow blade
#2 Cart
QA36 snowthower
Old 10-29-2018, 09:59 PM
20 years ago, I bought a Hobart auto-darkening,, it was perfect until 2 months ago,,,
I replaced it with this,,,
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
WOW, after 20 years,, they added a LOT of nice features to the new auto helmets,,
Old 10-29-2018, 10:09 PM
I picked up this Hazard Freight special last year for around $120. It really works nice and is probably made in the same China factory that 80% of all the other helmets are made in. It looks nice with my Chinese built Esab.
https://www.harborfreight.com/weldin...met-63749.html
Old 10-29-2018, 10:57 PM
I use special puller bolts at work that look just like those Jeff but much bigger . Mine are 3/4 x 10 with the long shank past the threads (all one piece) that I use to pull a drive unit mount plate/bearing cup with.
What do you use yours for? Looks pretty small and precise.
