Old 11-17-2018, 10:22 PM
Lonstar Lonstar is offline
Default Cab Heater on a 3000 series with a Kawasaki engine
Anyone ever done this with the liquid cooled Kawi engine? I have an all metal Sims cab, wondering if worth doing if I want heat.
Old 11-18-2018, 08:37 AM
Cab heat is always a good thing while blowing up a blizzard in a "T" shirt
Old 11-18-2018, 09:08 AM
cooperino's Avatar
Any heat better than none. Especially if you have glass in cab. Point A hose off heater at windshield to defrost!
Old 11-18-2018, 09:12 AM
You could run a loop to a finned radiator inside the cab. You would have to design a bypass circuit to turn on/off and/or moderate the coolant as the temp inside the can became too warm. A Circulating Fan would be even nicer.
Lot of things to think about.
Old 11-18-2018, 11:09 AM
I believe JD makes a kit that has a heater core, fan, branch hoses, controls, etc for their liquid cooled models. Probably lists for half the cost of the tractor.
Actually, not sure if made by JD or an aftermarket, but it's available. I've never come across one made by CC or aftermarket for a 3000 series.
The cab and blower are on a 3235, I don't have a liquid cooled Kawi (yet). I want see if anyone else has done it and explore what it would take. If feasible I'll start hunting for a 3205 with a bad rear or hydro selling for a good price. There was one for sale a few months ago about 2 hours from me. Hydro pump was bad, asking $500. I should have jumped on it but sat on the fence too long. By the time I called it was sold.
Old 11-18-2018, 12:29 PM
cooperino's Avatar
If you or anyone else wants. We have a few self contained heater cores in boxes with fans. We take the out of tugs with cabs. They have 2 2" ports coming off them one goes to the tube for defrost the other goes to a vent by feet. If i run out of used ones i have a source for new also
They look like this but have a little duct going from rectangular to round
Old 11-18-2018, 12:41 PM
They're hydronic, not electric heaters, right?
Judging by the picture looks to be 10" on each side? How much are they?
My thought was to find a thin core that would fit in the area the battery is in. Not sure how yet, and have to add the thickness for a fan behind it. I'll keep this in mind though, thanks.
Old 11-18-2018, 12:54 PM
cooperino's Avatar
Correct. inlet and outlet for water. It has a 12 volt fan in it. They are meant to be bolted to the inside of cab. I would run 2 hoses from coolant system with quick connects and same on heater side. Then when cab comes off in summer just connect the engine side hoses together
Old 11-18-2018, 07:03 PM
TNTs CC TNTs CC is offline
I'm very interested. I'm going to build a dedicated snow removal tractor out of my two parts tractors and will be using the Kawasaki engine in it. That way I don't have to remove the heavy 6 window long version Sims cab anymore. That thing is heavy, I use my engine hoist to install it.
As for hook up Y type tee goes in the bypass hose and the other hose gets spliced into the upper radiator hose with a tee.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 11-18-2018, 07:07 PM
The engine cooling fan draws air in across the battery threw the screen mounted under the dash. I doubt trying to blow air the other way will work real well. My plan was to mount one in the back corner of the cab.
