Old 08-13-2018, 12:25 PM
Terry C's Avatar
Terry C Terry C is offline
Sarcasm to how to answer problems aside, he said it with lean condition earlier. That’s my vote too. I’d give it a once over, focusing on the fuel. Cooling fins too, maybe marginal on that, and the lean condition made it really hot.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-13-2018, 04:12 PM
RLause's Avatar
RLause RLause is offline
I had that same thing happen one time.
Richard
Old 08-13-2018, 04:18 PM
i'm voting for the rod seizing to the crank, or the piston in the cyl.
Old 08-13-2018, 06:58 PM
Nice! Thanks for agreeing with me George. Now we wait......
Old 08-13-2018, 10:10 PM
john hall's Avatar
I don't like your vote!!! If that happens there will be 2 really nice ag tires and a hydraulic lift for sale.
Ya'll keep head scratching. I'll get around to it eventually. Gonna try to bale a little more hay between thunderstorms first.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-14-2018, 07:15 AM
I had a 14 hp Kohler years ago that acted exactly as described here. I changed the breaker points and the problem went away forever. The only thing I saw wrong with the points was a very weak spring but that fixed it.
Old 08-15-2018, 11:17 AM
Chad126's Avatar
Chad126 Chad126 is offline
Electrical doesn't make sense to cause the symptoms you are describing.
I'm voting for a valve issue.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 11-18-2018, 09:18 AM
john hall's Avatar
Well, didn't have time to let it run for a while to see if it fixed it, but Tim takes the lead with his guess. Here is a couple shots of the condenser wire and the wire going to the points. The condenser was BARELY attached to the coil. I also ran a new wire to the switch. Don't know if this was the problem but it certainly needed attention! FWIW, I didn't have a condenser for this, so I robbed one off a 682 parts machine. It cranked, that's all I can say as of now. Checking stock, I don't have any points of condenser for the K series on hand--need to put them on "the list".
2072 w/60" Haban
Old 11-18-2018, 09:42 AM
Looks like a little housecleaning is in order here.
May just solve other issues as well.
1st off, replace the wire from the coil to the points.
