Old 11-18-2018, 12:42 PM
mfeldmann mfeldmann is offline
Default Front log splitter on a GT ?
I have a 1650 twin-stick front hydraulics. Will the hydro pump work a front log splitter off the front hydraulics?
Old 11-18-2018, 12:52 PM
cooperino's Avatar
It would probably be very slow. Also I doubt it will split anything real large. My 20 ton splitter is 20hp. The pump runs at 3000 PSI @ 24 GPM.
Old 11-18-2018, 01:01 PM
The pressure on a Sundstrand Hydro is 600 PSIG Maximum. I am going to say NO.
Old 11-18-2018, 01:36 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Like they all said.... not enough volume or pressure with the stock charge pump on the hydro.. you would need to mount an aux pump and reservoir like they used with the loaders and such to effectively power a log splitter .. good idea though!
Jay
Proud owner of the following:
Old 11-18-2018, 04:13 PM
RLause's Avatar
RLause RLause is offline
You could build the quick attach mount to incorporate an auxiliary pump to run from your pto. Then you would need a tank and extra valve.
Richard
Old 11-18-2018, 07:36 PM
johncub7172's Avatar
Pulling a log splitter behind a 1450, or your choice of garden tractor, is just about as good of an idea. Though, somewhere I recall seeing a JD garden tractor with one mounted on the front, but don't recall the power source for the splitter.
Old 11-18-2018, 10:19 PM
In the 60's, there was a log splitter attachment made to fit on the rear axle of a cub. I think it bolted onto the lug bolts of the rear rim. Build a replica or find one of the originals. I have only seen them in brochures. Perhaps my Uncle Lewy has one for sale?
Old 11-18-2018, 10:32 PM
Ha! Totally forgot about that one. Its called a Unicorn. Prolly because they are rare as a unicorn? Last on I recall seeing here at OCC was being sold from member Wild Bill.
Old 11-19-2018, 06:46 PM
That’s a good analogy! This is probably known but It’s a screw type log splitter and the screw splitter looks like a unicorns horn.
Old 11-19-2018, 06:56 PM
Sounds like a good way to get hurt!!
