Old 12-10-2018, 06:13 PM
JoshM JoshM is offline
Default Cub Cadet 125 Shake
I know i’m posting a lot but I keep thinking of things that I could ask about. My tractor shakes quite a bit at an idle when its first starting up, not so much when its been running for a while. I have heard people say the Cubs do have a normal shake but this just seemslike a bit too much. I replaced two missing bolts on the front cast iron grill and that didnt really help. Any ideas?
Old 12-10-2018, 06:49 PM
More air in the front tires helps, didja check the engine bolts?
Old 12-10-2018, 08:51 PM
I never really looked, im about to take the engine out soon to but a gasket set on it, ill make sure its all good when I put it back on.
Old 12-10-2018, 09:39 PM
sawdustdad's Avatar
Loose engine hold-down bolts are very common. Some tractors I've come across only have one or two bolts, and those are usually loose, mostly from stripped threads.
Old 12-10-2018, 10:34 PM
Ok thanks.
