Old 12-11-2018, 10:27 AM
Woodtrucker Woodtrucker is offline
Default Carb Choices for K241
I have been trying to start up the Cub Cadet 100. Throttle shaft on carb seems really loose and wobbly so for the sake of winter and getting my machine up and running asap, I think I'm going to shoot for a replacement carburetor. Would either of these be a recommended buy? I am capable of modifying the throttle linkage to fit either model by way of machining if necessary. Just need my new cub up and running asap so I can push snow. Already had 15" of snow and it's not even mid december yet!
https://www.ebay.com/itm/Kohler-K241-K301-M10-12-Cast-Iron-10-12-HP-Carburetor-NEW-Replaces-CARTER-26/191136693833?epid=2087438874&hash=item2c80a27e49:g :CVYAAOxy3zNSjoMn:rk:5f:0
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
Cub Cadet 100 #66758
Old 12-11-2018, 10:40 AM
sorner's Avatar
sorner sorner is offline
https://isavetractors.com/kohler-car...0-m12-engines/
You want to make sure to get one with the two different choke shafts. Because in my experience they always come with one installed that is backwards and wont work with the choke cable in these tractors. So you swap out the choke shaft and it works. Be careful to not lose the little ball in the choke shaft hole. When you pull out the choke shaft it will pop out because it has a spring behind it.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 12-11-2018, 12:03 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Depending on how loose it is you might be able to just buy the throttle shaft. My brothers JD had the throttle so worn it was oval shaped. Replaced the throttle shaft and took 75% of play out of it.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 12-11-2018, 01:37 PM
Install the bushing
