Old 12-28-2018, 09:53 PM
RicochetFord RicochetFord is offline
Just to close this one out and post the solution for someone in the future.
I finally figured out what my issue was, broken connection on one leg of the top contact point. After watching this video, https://m.youtube.com/watch?v=5ngzb_Avfkk, I was better able to understand what is supposed to happen and ohm out each connection.
A quick remelt and attach and we are showing charge on the gauge, will run without the battery.
My VM is still jumping around but I have heard the Harbor Freight ones will do that. About 16 on the S/G and 14 at the battery.
Old 12-29-2018, 10:40 AM
RLause's Avatar
RLause RLause is offline
50 years ago my boss in the 2-way radio dept. where I worked, said you could fix half the problems just by using your eyes. I've found this true most of the time.
Richard
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Voltage Reg.
Are you talking about the top contact point on the new voltage regulator? Wouldn't the new voltage regulator have cured it if the old one was bad? I am lost here and probably don't understand what is going on. Glad you got it fixed and have a great day.
Bob
Old 12-29-2018, 11:09 AM
Bob
The bad solder joint was on the new VR, the contact was opening and closing like it should but when it closed it was not doing anything.
