Old 12-30-2018, 11:48 AM
dads70's Avatar
dads70 dads70 is offline
Default What options were there for the model 70?
where can I find what all options were available for the model 70-100 tractors when new?attachments ect...
Old 12-30-2018, 01:16 PM
Gompers Gompers is offline
Well there are options and then there are attachments and they are two different things.
IH made or sold under the IH name snow throwers, mowers, plows, rear rakes, trailers, tillers, peg tooth harrows, sand trap rakes and lawn sweepers. There were lots of other third party attachments you could get as well. Not sure if all of those fit a 70 or not. I’m not an expert in the old old ones.
Options on the 70 were electric start, headlights, creeper drive, three point, weights, dual rear wheels, hydraulic lift, seat pad, rear utility box, fenders and maybe a couple of other things.
Most of it is covered in the sales brochure.
Old 12-30-2018, 03:15 PM
dads70's Avatar
thanks.... that covers it
Old 12-30-2018, 04:43 PM
- Select --
220 32" Lawn Sweeper 190-220-100
222 38" Lawn Sweeper 190-222-100
368 10 Cu. Ft. HD Utility Cart 190-368-100 190-368A100 190-368B100
38" Hitch and Drive for 3 Spindle Deck
38" Mower -2 Spindle-
38" Spindle Mower Drive For 70
38", 42" 3 Spindle Mower
38", 42", 48" 3 Spindle Deck Drive Unit & Hitch
38", 42", 48" Quick Attach Hitch (70 & 100)
42" Back Blade
42" Push Blade
42", 54" Push Blade - 1
425/425A 17 Cu. Ft. Utility Cart
438 Broadcast Spreader
48" 3 Spindle Deck
521 Utility Cart
653/653A 10 Cu. Ft. Utility Cart
CC36, CC42 Snowthrower
CW36 Snowthrower
Manual Lift Helper Spring & Handle Adapter
Peg Tooth Harrow
PTO Clutch Attachment, Engine Driven
PTO Clutch, Engine Driven
PTO, Engine Driven
QA36, QA42 Snowthrower
QA36A, QA42A Snowthrowers
Sand Trap Rake
Tiller #1 Front Drive
Tiller #1A Front Drive
Trailer #1 Built 1960 - 1967
Old 12-30-2018, 05:06 PM
Rear pto.
Hub caps.
Horn.
Spliff lighter.
Amp meter.
Up to 534 and counting...
Old 12-30-2018, 06:47 PM
Spliff lighter.
Dave’s not here!
Old 12-30-2018, 07:06 PM
I know, tried to slip that one by you....
Old 12-31-2018, 12:07 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Creeper drive
