Old 01-17-2019, 08:15 PM
Steve N Mi Steve N Mi is offline
Default Questions on 1811 and 1872
Are the side panels interchangeable, the same on both of these?
Will 26X12X12 rear tires and wheels fit on the 1811?
Old 01-17-2019, 08:26 PM
Gompers Gompers is offline
Side panels are the same. Don’t know for sure on the wheels, but I suspect they won’t work without lifting the fenders. Haven’t tried it.
Old 01-17-2019, 08:33 PM
Thanks for the fast reply. Is the engine and hydro the same on both?
Old 01-17-2019, 08:37 PM
CubDieselFan's Avatar
Engine is, hydro is not. What is your plan to do?
Edit: The 1872 is the better of the 2 if you are making one out of the 2 tractors.
Old 01-17-2019, 08:38 PM
Engine is. Hydro on the 1872 is the same unit, but has a splined input shaft. The driveshaft is obviously longer. They are mostly interchangable depending on what you are trying to do.
Old 01-17-2019, 08:40 PM
Looking at this 1811 as a parts doner for my 1872's
Old 01-17-2019, 08:44 PM
I should have said CONSIDERING the 1811 as a doner. Likely it will be a sight unseen purchase, pickup later.
What is wrong with 1872?
Old 01-17-2019, 08:46 PM
Engine is a no brainer. You could make the hydro unit work, though it’s not ideal.
Old 01-17-2019, 08:51 PM
I think the output gear is different as well.
