Old 01-10-2019, 08:42 AM
yingpin yingpin is offline
I'd guess that your carriage bolts you'd want to mount the wheel weights to the rear rims would be 1/2" ? You might be able to drill that with a regular electric hand drill, starting with two smaller bits and finishing with the 1/2" bit. You'd only need two holes per weight.
Nice purchase, btw!
Are you saying to drill out two new holes offset from the existing slots? You are correct, I have 1/2' carriage bolts. I guess your right about only needing two bolts per wheel instead of 4. It is so close that I was thinking I could grind it down with the angle grinder and grinding wheel. 8 would take a heck of a lot longer than 4 so maybe I will try to get two cut down and go from there.
Old 01-10-2019, 09:33 AM
johncub7172's Avatar
Morning!
It was just another way I thought could be helpful. But, if you have a good, new cookie wheel then your way should work fine!
Good luck!!!
Old 01-10-2019, 06:56 PM
I did some grinding realizing that I only needed to get two bolts in to hold these weights on so that cut the time needed in half. I still need to take them down a little more but they work. Oh I sanded them down since they were so rusty, primed and painted them for some flare!
Quick questions....
1) The blade rear bars, they lined up better on the outside of the frame near the foot rests, should they be inside the frame? I should be able too flex them to the inside but I am not sure if it makes a difference?
2)To install the sleeve hitch, is there a panel that needs to be removed? The video I found online shows an install but mine looks like it has a cover panel.
File Type: jpg 03798153-E5A9-421A-9AAD-B4D7F9A2D318.jpg (39.2 KB, 130 views)
File Type: jpg C49318FF-8C73-4848-9D9F-34C3425EB888.jpg (36.8 KB, 129 views)
Old 01-10-2019, 08:38 PM
Quick questions....
Outside the frame, on the bars between the footrest and frame is where they should rest on.
Remove the back panel with the IH sticker on it. You will not be using that again if you leave the 3 point on.
Old 01-17-2019, 01:55 PM
With your rear lift, it looks like all you maybe missing is the bushing that slips in the lift bar when you bolt that bar to the rear lift casting.
It's 3/4" in diameter with a 1/2" clearance hole that is 1/16" thicker than the lift bar.
Nice get
Can you get this bushing anywhere (HD, TSC, ACE, LOWES) or online?
Old 01-17-2019, 09:21 PM
I can make you one for cheap. It's a piece of 3/4" round with a hole that a 1/2" bolt fits thru and just slightly wider than the lift bar.
Jeff
Old 01-18-2019, 06:30 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Man, you did really well!
congrats on the nice deal.....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-22-2019, 10:20 AM
Thanks for the help so far on this one. I have a lot to learn about tractors and the mechanics of them. Its been too cold to tinker with it the past week. I have noticed that the LR tire is flat and will only hold air for about 2 days lately. They are Carlisle Turf Savers but I am not sure how old they are. They look pretty worn, hard and have some cracking.
I have been thinking about moving to the Carlisle Tru Power 23x8.5. Would the chains I have fit over the Ags? I would imagine so since they would be the same size tire but they just look meatier. As little as this thing will get used, I am not opposed to something cheaper. Also considering the use, I could just stick with newer turfs. I will primarily be moving firewood, using yard implements and plowing/blowing snow when we get it.
Old 01-22-2019, 11:03 AM
Those 4 link chains will jar the fillings out of your teeth after very long.
2 link chains would be much better.
I'd Keep an eye out for a set.
Old 01-22-2019, 11:44 AM
crazycubtrio crazycubtrio is offline
My two boys moved a lot of snow this past weekend, one has turf tires with chains the other with ags and they both do the same amount of pushing. I wouldn't bother putting chains on the ags especially if you fill them.
