Old 06-01-2009, 05:20 PM
B1jetmech's Avatar
B1jetmech B1jetmech is offline
Default Kohler K361
Has anyone had experience with this motor? I notice it's a modified K341 except it has an OHV cylinder head and the oil pan is larger. I don't know the availability of these motors but parts shouldn't be too hard to come by. Do like it.
Thinking of swapping it in the 1450.
Chase
Old 06-04-2009, 12:32 PM
drysumpjet's Avatar
drysumpjet drysumpjet is offline
I am not sure but all the K361s I have seen on the auction site have a wide base which won't fit into a cub frame without extreme modification to the block.
Also since the carb is higher, it might interfere with the hood.
I read somewhere, the K361s had rocker arm issues, I wonder how they got oil up there without an oil pump?
Others may be able to comment further on this. I thought of pursuing this too, but for me the "wide base" block is a showstopper.
I found the K341, 16hp, is a nice step up in power over the K321, especially when ported.
Old 06-04-2009, 12:51 PM
Parts are going to be hard to come by. The connecting rod went NLA a couple years ago, and I'm sure a lot of other things are too. I've only ever seen one of these engines. They really shake too. I'd just leave the 1450 as is...
Old 06-04-2009, 01:42 PM
B1jetmech's Avatar
Thanks for the tips guys, I, backing off from the ideal because of "would be" logistical issues because of a lack of parts.
Chase
