Old 01-24-2019, 08:53 PM
Default $55 For FREE
If you bought a mower within the last couple decades,, you are probably eligible for up to a $55 settlement,,,
Lawnmower makers settle class action lawsuit
That is better than free grinding disks!!
I figure they owe darkminion_17 one point two million dollars,,,
Old 01-24-2019, 10:23 PM
Farmall450's Avatar
These things are normally a scam w/ the lawyers taking home several times what the "hurt" get.
Old 01-24-2019, 10:35 PM
MarkEagleUSA MarkEagleUSA is offline
"you purchased the Lawn Mower in Canada."
Mark
1641
Old 01-24-2019, 11:03 PM
john hall's Avatar
Now who in the heck on this list would actually go buy a new lawn mower??? I thought a membership requirement was you had to fix it up before you could mow with it??
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-25-2019, 11:04 AM
Well, I'll be!!!
30 HP or less and all you have is a damned "lawn lower"???
Well.... Burst my bubble will Ya???!!!
Old 01-25-2019, 03:02 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
that sums it up reeeally well
1- 1200 in pieces
1- 1864 in pieces
Old 01-25-2019, 03:20 PM
CC2140 CC2140 is offline
Had to be purchased in Canada, so that eliminates the majority of us, other than that I fall in that window for two mowers. I could have restocked my bar with beer for a while.
Old 01-25-2019, 06:14 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Hang on to the two mowers....stupid US lawyers could now get the idea!
Plow blade
#2 Cart
QA36 snowthower
