Old 02-12-2019, 09:51 PM
rsshallop rsshallop is offline
OK, two taps and the cup is off. Hairline cracks on both sides of the hole for the locator pin. Do you think the cup can be fixed or should I just try to find a good used replacement? As for your suggestion on cleaning up the threaded holes in the flywheel - Yes, I will definitely follow your advice once I get a good tap and die set.
Old 02-12-2019, 10:07 PM
athomas's Avatar
athomas athomas is offline
I'd look for a good used one but if not too bad clean up the outside boss and put some epoxy-JB weld around the cracks maybe and clean the hole out with a bore brush might be ok to reuse ! clean up the pin on flywheel and use some anti seize when going back together should be ok once everything is bolted back together !
athomas, don't bother replying to my last question about repairing the cup. It's dumb and you have already helped me more than enough. Anyway, I just bought a replacement on ebay for about $60.00 shipping in. Costly mistake though mine was missing the screen. Thanks again. Ross
Old 02-12-2019, 10:10 PM
athomas's Avatar
Not a problem , I always said the person that never makes a mistake likely doesn't do much !
